12-13-2018, 09:31 PM
Anyone Installed Lift Kit On A 2018 Classic 33FB?
Our 2018 Classic 33FB is wonderfully comfortable, low and long. I often worry as I carefully maneuver to avoid dragging or backing that long rear end and low sewer connect. Three more inches of clearance would be great when visiting the rougher and more scenic parks and hilly urban areas. Has anyone installed a Dexter Lift Kit? Is the Dexter #11 a good bolt on fit? I am concerned about fitment with the belly tanks and ability to handle the heavy load of a 33FB. Thanks for your help.
12-14-2018, 06:12 AM
ObviouslyKnot
KAILUA
, HI
http://www.airforums.com/forums/showthread.php?t=189927
Seen this recent thread? Don't remember any 2018's in the sea stories.
James Mileur, HY80-2-Al,
2017 Classic Twin, 2016 RAM 3500 Megacab, ProPride hitch
01-02-2019, 11:29 AM
2017 22' Sport
Johns Creek
, Georgia
Did you get the lift? If so how is it working out and did it change your towing any? This is something I’d like to do if we purchase the same 2019 unit.
01-03-2019, 10:46 AM
2016 30' Classic
Lorton
, Virginia
This is definitely on my to-do list.
01-10-2019, 10:21 PM
I called Dexter and gave them the numbers on my 2018 Classic 33FB axles. I have the 11 axles and they assured me the lift kit could handle the weight of the 33FB and should fit the frame mounting configuration. He said Airstream’s install of the tanks and covers was more custom than uniform, so I might need to get creative to accommodate wrench access to some of the fasteners, but it should fit without any drilling to the frame. When I asked about the effect on towing, he said I should raise my weight distribution tow ball the same three inches the lift kit raises the trailer and I should be good to go. The kit arrived two days later. I will install it when I get the unit back from warranty repairs on the projector and plumbing.
01-11-2019, 06:52 AM
2017 22' Sport
Johns Creek
, Georgia
Great, thanks for the update! Looking forward to hearing again after your install.
01-11-2019, 11:11 PM
2018 30' International
2016 28' International
2010 25' FB Flying Cloud
St Augustine
Thumbs up on the Dexter lift. We installed this on our 30ft INTL to give us more ground clearance (esp. tail-drag). I had suspected there wouldn’t be any noticeable handling difference which ended up being true. Very happy.
01-11-2019, 11:12 PM
St Augustine
I meant to add: Of course we had to re-adjust our ProPride hitch setup.
01-12-2019, 02:03 AM
2017 30' International
Broomfield
Great to hear. My kit arrived and I plan to install on my 30’ international.
Did you install yourself? How hard was it to get at the bolts given the water tank covers?
01-12-2019, 09:25 PM
2018 28' Flying Cloud
Chapin
, South Carolina
I can't speak specifically to the 30ft, but when I installed the kit on my 28ft in October, my tanks blocked bolt access to at least one bolt head on all four blocks. My work around was buying a cheap 15/16 combination wrench, cut it in half, taped each to end of pieces of rebar to make a long extension. This reached through the frame channel between tank and frame to get to the bolt heads to hold them. Some worked better with open end, others with box end.
01-26-2019, 03:03 PM
Broomfield
My Dexter lift is being installed on my 30” international on Monday. Timeless Travel trailers in Denver are doing the work for me in their shop - 6 hours labor.
Swapped out the shank on my equalizer to raise the ball 3” to accommodate the lift.
Pictures to follow of the lifted rig - no more dragging the rear end over the smallest undulations in parking lots!
01-26-2019, 05:00 PM
2015 25' FB Eddie Bauer
2013 25' FB Eddie Bauer
2012 20' Flying Cloud
Small Town
Nice choice ...
01-26-2019, 05:09 PM
2019 27' Flying Cloud
Box Elder
, South Dakota
So...are we going to need a lift kit on our (prospective) 27FB? We tend to get off the flat quite a bit...
01-27-2019, 08:41 AM
2013 25' International
Boise
, Idaho
Lift Installation
Wulfraat - how'd it go, we want to see!
-A
01-27-2019, 01:38 PM
Broomfield
Install is tomorrow more to come stay tuned....
01-27-2019, 01:57 PM
Boise
, Idaho
Mostly just cause I am dreaming..
Here's my trailer last Spring after our custom 4" lift. I still think its the best upgrade I've done.
01-27-2019, 07:48 PM
St Augustine
We had our lift installed so I couldn’t speak to any issues with the bolts.
In addition to the lift kit, we also installed 16 inch wheels and tires so we run a lot higher then the standard 30ft INTL (ours is a 2018).
I’ll take some pictures next time we have it out (in storage now).
01-31-2019, 05:53 PM
Broomfield
Shazam! The 30’ International is lifted! Love it! Should be a factory option.
01-31-2019, 07:00 PM
2017 22' Sport
Johns Creek
, Georgia
[emoji106]
01-31-2019, 07:21 PM
2013 31' Classic
billings
, Montana
I did our 2013 31’ Classic...3” lift...really like it , been to Nova Scotia, to the west coast...
