Old 12-24-2018, 09:09 AM   #1
Augianderson's Avatar
Grants Pass , Oregon
Alde leaks to outside (2017 Classic)
Alde leaks to outside. Stephen at Alde says sometimes the valve will lockup if/when bumps occur while moving. Anyone else encounter this? Have new valve on order through Airstream of Scottsdale.
Augianderson is offline   Reply With Quote
Old 12-24-2018, 10:22 PM   #2
2018 33' Classic
Silverdale , Washington
Yes I have experienced Alde system leakage. Where is Alde system leaking and is it glycol or water?
CWO7241 is offline   Reply With Quote
Old 12-25-2018, 09:03 AM   #3
Front curbside of Airstream, leaking glycol
Old 12-25-2018, 09:17 AM   #4
Correction...drivers side
Old 12-25-2018, 11:39 AM   #5
Classy Roscoe
Jekerrville's Avatar
1969 31' Sovereign
Kerrville , Texas
You may have on issue at all. If you have not had your AS at elevation with Adle on, it can dump a little coolant out the overflow. Check the fluid level of the tank that is located behind the access panel in the cabinet above the head.
Jekerrville is offline   Reply With Quote
Old 12-25-2018, 11:40 AM   #6
Classy Roscoe
1969 31' Sovereign
Kerrville , Texas
That's NO issue
Old 12-25-2018, 02:38 PM   #7
Thank you so much. I checked the fluid & had to fill it backup between Min & Max serval times. So believe it is the valve being stuck out of closed position.
Old 12-25-2018, 10:04 PM   #8
Obviously-NOT
james.mileur's Avatar
Kalispell , Montana
Have tried tapping the auto vent valve?
James Mileur, HY80-2-Al,
2017 Classic Twin, 2016 RAM 3500 Megacab, ProPride hitch
james.mileur is offline   Reply With Quote
Old 12-26-2018, 08:13 AM   #9
Yes, several times.
Old 12-30-2018, 03:42 PM   #10
Obviously-NOT
Kalispell , Montana
Have received the replacement? Stop the leak?
If not, can try removing the valve, messy if expansion tank full, but keep your finger on the hole, while shaking out or purging the vent valve, maybe shaking vigorously under water in a bucket? Maybe a removable Schrader valve in the assembly, like the vents in NE circulating hot water systems.
A 5' head of fluid to the tank will only be about .4 psi squirting out. Finger stoppable. But messy.
Old 01-12-2019, 07:58 AM   #11
Under warranty the dealer replaced the Alde valve & heater now works like new. Best to beware of bumps in the road, I guess.
First Alde 3010 boiler to Alde 3020 boiler and Alde flow upgrade Sparr 2016 - Current Classic (all lengths) 44 01-03-2019 09:05 AM
ALDE HEATING SYSTEM FAILURE- Alde glycol discoloration and vent discharge JimskyD 2016 - Current Classic (all lengths) 50 05-25-2018 08:48 AM
Problem with safety valve popping between Alde flow and Alde paul.kukstis 2016 - Current Classic (all lengths) 7 04-08-2018 07:09 AM
Leaks, leaks, leaks jeffnjen30 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 8 08-28-2007 12:03 AM
leaks leaks leaks Globie64 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 10 12-31-2005 06:49 PM
