Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Classic > 2016 - Current Classic (all lengths)
Old 11-20-2019, 04:05 AM   #1
2019 30' Classic
Norcross , Georgia
Alde Exterior Temp Sensor Location?
My Alde screen has stopped accurately showing the exterior temp. It was working well last fall/winter but is now showing about 10-15 degrees higher than actual temp.
Does anyone know where the sensor/probe is located so I can see if it needs to be cleaned or adjusted--I've tried the refrigerator exterior compartment but no luck.
Thanks!
PaulR-GA is offline   Reply With Quote
Old 11-23-2019, 04:39 PM   #2
BigSxyWhtGuy's Avatar
2018 30' Classic
Thousand Oaks , California
I know the front one is under the cabinet above the sink. Little black guy that says Alde on it. I believe the rear one is next to the TV.
I’m in a 30 queen. This may be different for twin and 33s
BigSxyWhtGuy
Follow our adventures!
@airstreamvagabond on Instagram and YouTube
BigSxyWhtGuy is offline   Reply With Quote
Old 11-26-2019, 04:48 PM   #3
2018 30' Classic
Cumberland , Maryland
I believe they are referring to the outside sensor which we do not have. Or at least we don't have on our 2018, 30'Q. I would take Alde Panel off and check the connectors.
Airhead2018 is offline   Reply With Quote
First Alde 3010 boiler to Alde 3020 boiler and Alde flow upgrade Sparr 2016 - Current Classic (all lengths) 64 08-15-2021 06:36 AM
ALDE HEATING SYSTEM FAILURE- Alde glycol discoloration and vent discharge JimskyD 2016 - Current Classic (all lengths) 50 05-25-2018 07:48 AM
Problem with safety valve popping between Alde flow and Alde paul.kukstis 2016 - Current Classic (all lengths) 7 04-08-2018 06:09 AM
location location location goransons Airstreams on eBay 0 12-05-2009 09:29 AM
Location, Location, Location........... ROBERTSUNRUS Brakes & Brake Controllers 5 08-29-2009 06:13 PM
