Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Classic > 2016 - Current Classic (all lengths)
Old 05-01-2018, 03:57 PM   #1
Anywhere , Alabama
Alde Control Panel
Okay, got a weird one. Have a 2017 Classic that has an Alde heating and hot water system. The 3010 control panel has stopped responding to some button pushes. Also, it initiates some actions without a button push. Took the front cover off and it works perfect. Put it back on, issue returns. Anyone else seen this?5
Matt & Pam Padgett
Anywhere, USA
2016 Ford F-350 Dually
lukeysh714 is offline   Reply With Quote
Old 05-01-2018, 04:05 PM   #2
2007 22' International CCD
look for a stuck button or the like when the control panel is back on?
Look for a pinched cable or a wire that is trapped under the panel?
Gently press on the circuit boars with the eraser end of a pencil to flex it and see if something changes.
Make sure all the connectors and mounting screws are properly fastened.
What Alde system does Airstream Use. Lets travel Classic Motorhomes 15 06-06-2021 06:14 PM
Alde system classic twin cegardner 2006 - 2010 Classic (all lengths) 2 02-18-2019 06:38 AM
ALDE HEATING SYSTEM FAILURE- Alde glycol discoloration and vent discharge JimskyD 2016 - Current Classic (all lengths) 50 05-25-2018 07:48 AM
Problem with safety valve popping between Alde flow and Alde paul.kukstis 2016 - Current Classic (all lengths) 7 04-08-2018 06:09 AM
ALDE LP Radiant heat? Zybane 2016 - Current Classic (all lengths) 1 05-06-2016 03:39 PM
