Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Classic > 2016 - Current Classic (all lengths)
Old 05-08-2019, 06:34 PM   #21
Roadtoaster's Avatar
2019 30' Classic
Byhalia , Mississippi
this thread has been an enormous help to me while on a 10 day trip. i read the much ado thread but apparently failed to absorb the info. finally found the dial on the pump and it was set on 5. alde flow box was not checked on the control panel. fixed both and now have unlimited screaming hot water. thanks everyone.
Greg
Roadtoaster is offline   Reply With Quote
Old 05-08-2019, 06:52 PM   #22
2019 30' Classic
Belen , New Mexico
Originally Posted by Froglips View Post
Not there Although, the ACC button on the main menu is greyed out.
That's really strange that the Accessories is greyed out. You may need to contact Airstream if this is a 2019. I'm not sure about 2018 or earlier. I don't know whether they have the Flow or not, but the whole menu being greyed out is rather strange.
Give them a call. They haven't always had the answer for me when I've called, but they really try and they usually give me enough information that I can solve it on my own.
Ephraim is offline   Reply With Quote
Old 05-08-2019, 06:53 PM   #23
2019 30' Classic
Belen , New Mexico
Glad I could help.
In the three weeks I was waiting to take delivery, I downloaded every manual I could get my hands on and read the cover to cover. My wife always makes fun of my propensity to relax by reading technical manuals.
Old 05-12-2019, 10:01 AM   #24
2019 30' Classic
LEES SUMMIT , Missouri
great thread !!
I too think this is a great thread !! I have the same problem in my 2019 30' Classic that is being described. The factory and my dealer concluded I wasn't getting hot water in the shower due to a bad shower valve, but I am guessing I have the same problem everyone on this thread is describing -- that there is a box in accessories that isn't checked. I'll try that the next time I get the AS out of storage.
dechampion is offline   Reply With Quote
Old 05-13-2019, 04:03 AM   #25
2019 30' Classic
2012 25' FB Eddie Bauer
Crested Butte , Colorado
Please let us know IF you find the Alde Flow accessory on your screen. I had a 2019 30" Classic and do not had that accessory available.
Froglips is offline   Reply With Quote
Old 05-14-2019, 01:23 PM   #26
2019 30' Classic
Vero Beach , Florida
Found it!
Great info. I didn’t know I had Alde Flo till I read this.
I attached a photo for others.
WorkBGone is offline   Reply With Quote
Old 05-29-2019, 06:06 PM   #27
2019 30' Classic
Finally took the 2019 Classic out of storage and checked my accessory settings on the Alde system. Sure enough, I have the Alde Flow listed but the box was not checked. I therefore checked the box. Haven't tested to determine whether I have more hot water. However, attached are pictures of the other accessories that are listed and none of the boxes were checked. Does anyone know if I should check all of the other boxes too?
Name:	19.05.29 Alde control 1.jpg
ID:	342051   Click image for larger version
Name:	19.05.29 Alde control 2.jpg
Old 07-17-2019, 08:56 PM   #28
TowingTom
2018 27' Globetrotter
Santa Ana , California
Mixer issue
2019 newly purchased Classic 30 had only warm water at shower. Sanitary water temp indicated at Alde panel 145+. Isolated problem to the mixer valve and made adjustments to the mixer to max hot water to hot service line. Adjustment resulted to no change still just warm. Discovered a shut off valve on the cold line just before the mixer and decided to try shutting off the cold water going into the mixer. Result- 130+ Hot water coming from the shower! The question is other than the need for care as we adjust the temp during a shower, what other issues will arise from shutting down the cold input to the mixer? Including a photo of the lines & mixer, viewed from galley side toward driver side.
TowingTom is offline   Reply With Quote
Old 07-18-2019, 05:47 AM   #29
turk123's Avatar
2019 30' Classic
Canfield , Ohio
Wait! How is it getting supply water with the cold shut off? Isn't that the only source of new water to the Alde?
"At some point, throwing money at the problem *is* the right answer", Uncle Bob
x\x/x\x/x\x/x\x/x\101970\x/x\x/x\x/x\x/x\x/x\/x\x/x\x/x
Tom & Doty
2019 Airstream Classic 30 Twin
turk123 is offline   Reply With Quote
Old 07-19-2019, 12:29 PM   #30
TowingTom
The cold water line that feeds the mixer branches off the cold line going into the Alde boiler. Of course this is the plumbing in our 2019 Classic 30. Each build could have a different plumbing plan.
Old 07-14-2020, 07:08 AM   #31
2019 33' Classic
Clermont , Florida
Alde Flow Box Leak
Thanks everyone for your posts here. We have a 2019 Airstream Classic 33'. Last Friday we noticed a trickle of water that appeared on the floor next to the dinette bench covering the Alde system. It is a very slow trickle. Things are tight under there, but I believe I was able to trace the water leak to the Alde Flow Box. We bled the system and we shut the water off and drained the hot water tank to restore the air cushion in hopes that it was a pressure issue. It wasn't and the leak continued after starting everything back up. Has anyone had this problem where the Flow Box (red with black end caps) begins to leak water? If so, do you have a solution short of taking it back to JC or a dealer?
Don Hale
WanderGators is offline   Reply With Quote
Old 07-15-2020, 08:21 AM   #32
BigSxyWhtGuy's Avatar
2018 30' Classic
Thousand Oaks , California
Can you take a picture?
BigSxyWhtGuy
Follow our adventures!
@airstreamvagabond on Instagram and YouTube
BigSxyWhtGuy is offline   Reply With Quote
Old 07-16-2020, 06:11 AM   #33
2019 33' Classic
Douglas , Alaska
Picture of Alde “Flow Box”
We have a picture but it doesn’t really show anything. It is difficult to see the water but it is coming from the box’s right hand corner (underneath). It is a small leak thank goodness, but it is constant and adds up. Any ideas you have is much appreciated.
Thanks for writing.
Don Hale
WanderGator is offline   Reply With Quote
Old 07-16-2020, 07:34 AM   #34
2018 30' Classic
You guys have a different system than us I believe. We had a leak in ours but it went out the bottom of the trailer. It ended up being a check valve that took us a couple seconds to fix. Alde America support is great over the phone but if you guys are already going to JC then you will be taken care if there. Keep in touch!
BigSxyWhtGuy
Old 07-24-2020, 05:25 PM   #35
2019 33' Classic
Clermont , Florida
Alde Flow Box
Update...After being in Jackson Center for the past week, the problem, as we thought, was a leak in the Alde Flow Box, the red box located on the back right hand side under the dinette bench seat closest to the door In the 2019 Airstream Classic 33’. The Flow Box was not secured to floor and likely took a few bounces before it began to leak. The Flow Box was replaced under warranty as well as all sleeves around the pipes. Best advice is for all with 3020 Alde systems to make sure your Flow Box is secured to floor.
First Alde 3010 boiler to Alde 3020 boiler and Alde flow upgrade Sparr 2016 - Current Classic (all lengths) 64 08-15-2021 06:36 AM
Alde system classic twin cegardner 2006 - 2010 Classic (all lengths) 2 02-18-2019 06:38 AM
ALDE HEATING SYSTEM FAILURE- Alde glycol discoloration and vent discharge JimskyD 2016 - Current Classic (all lengths) 50 05-25-2018 07:48 AM
Problem with safety valve popping between Alde flow and Alde paul.kukstis 2016 - Current Classic (all lengths) 7 04-08-2018 06:09 AM
Parrallax 3020 converter acting up Lothlorian Batteries, Univolts, Converters & Inverters 5 06-16-2008 06:05 PM
