Old 05-08-2019, 07:34 PM   #21
Roadtoaster's Avatar
2019 30' Classic
Byhalia , Mississippi
this thread has been an enormous help to me while on a 10 day trip. i read the much ado thread but apparently failed to absorb the info. finally found the dial on the pump and it was set on 5. alde flow box was not checked on the control panel. fixed both and now have unlimited screaming hot water. thanks everyone.
Greg
Roadtoaster is offline   Reply With Quote
Old 05-08-2019, 07:52 PM   #22
2019 30' Classic
Belen , New Mexico
Originally Posted by Froglips View Post
Not there Although, the ACC button on the main menu is greyed out.
That's really strange that the Accessories is greyed out. You may need to contact Airstream if this is a 2019. I'm not sure about 2018 or earlier. I don't know whether they have the Flow or not, but the whole menu being greyed out is rather strange.
Give them a call. They haven't always had the answer for me when I've called, but they really try and they usually give me enough information that I can solve it on my own.
Ephraim is offline   Reply With Quote
Old 05-08-2019, 07:53 PM   #23
2019 30' Classic
Belen , New Mexico
Glad I could help.
In the three weeks I was waiting to take delivery, I downloaded every manual I could get my hands on and read the cover to cover. My wife always makes fun of my propensity to relax by reading technical manuals.
Old 05-12-2019, 11:01 AM   #24
2019 30' Classic
LEES SUMMIT , Missouri
great thread !!
I too think this is a great thread !! I have the same problem in my 2019 30' Classic that is being described. The factory and my dealer concluded I wasn't getting hot water in the shower due to a bad shower valve, but I am guessing I have the same problem everyone on this thread is describing -- that there is a box in accessories that isn't checked. I'll try that the next time I get the AS out of storage.
dechampion is offline   Reply With Quote
Old 05-13-2019, 05:03 AM   #25
2019 30' Classic
2012 25' FB Eddie Bauer
Crested Butte , Colorado
Please let us know IF you find the Alde Flow accessory on your screen. I had a 2019 30" Classic and do not had that accessory available.
Froglips is offline   Reply With Quote
Old 05-14-2019, 02:23 PM   #26
2019 30' Classic
Auburn , Massachusetts
Found it!
Great info. I didn’t know I had Alde Flo till I read this.
I attached a photo for others.
WorkBGone is offline   Reply With Quote
Old 05-29-2019, 07:06 PM   #27
2019 30' Classic
Finally took the 2019 Classic out of storage and checked my accessory settings on the Alde system. Sure enough, I have the Alde Flow listed but the box was not checked. I therefore checked the box. Haven't tested to determine whether I have more hot water. However, attached are pictures of the other accessories that are listed and none of the boxes were checked. Does anyone know if I should check all of the other boxes too?
Name:	19.05.29 Alde control 1.jpg
ID:	342051   Click image for larger version
Name:	19.05.29 Alde control 2.jpg
Old 07-17-2019, 09:56 PM   #28
TowingTom
2018 27' Globetrotter
Santa Ana , California
Mixer issue
2019 newly purchased Classic 30 had only warm water at shower. Sanitary water temp indicated at Alde panel 145+. Isolated problem to the mixer valve and made adjustments to the mixer to max hot water to hot service line. Adjustment resulted to no change still just warm. Discovered a shut off valve on the cold line just before the mixer and decided to try shutting off the cold water going into the mixer. Result- 130+ Hot water coming from the shower! The question is other than the need for care as we adjust the temp during a shower, what other issues will arise from shutting down the cold input to the mixer? Including a photo of the lines & mixer, viewed from galley side toward driver side.
TowingTom is offline   Reply With Quote
Old 07-18-2019, 06:47 AM   #29
turk123's Avatar
2019 30' Classic
Canfield , Ohio
Wait! How is it getting supply water with the cold shut off? Isn't that the only source of new water to the Alde?
x\x/x\x/x\x/x\x/x\x/x\x/x\x/x\x/x\x/x\x/x\x/x\x/x
2017 Airstream International Signature 27FB Twin
2019 Airstream Classic 30 Twin
Our Google images and chat: https://photos.app.goo.gl/CMQbpNXQwapMnj8t9
turk123 is offline   Reply With Quote
Old 07-19-2019, 01:29 PM   #30
TowingTom
The cold water line that feeds the mixer branches off the cold line going into the Alde boiler. Of course this is the plumbing in our 2019 Classic 30. Each build could have a different plumbing plan.
First Alde 3010 boiler to Alde 3020 boiler and Alde flow upgrade Sparr 2016 - Current Classic (all lengths) 51 06-04-2019 05:54 AM
Alde system classic twin cegardner 2006 - 2010 Classic (all lengths) 2 02-18-2019 07:38 AM
ALDE HEATING SYSTEM FAILURE- Alde glycol discoloration and vent discharge JimskyD 2016 - Current Classic (all lengths) 50 05-25-2018 08:48 AM
Problem with safety valve popping between Alde flow and Alde paul.kukstis 2016 - Current Classic (all lengths) 7 04-08-2018 07:09 AM
Parrallax 3020 converter acting up Lothlorian Batteries, Univolts, Converters & Inverters 5 06-16-2008 07:05 PM
