Old 05-17-2019, 07:00 PM   #1
turk123's Avatar
2019 30' Classic
Canfield , Ohio
Adventures with Classic 30 Solar (and others)!
I thought I would post a real-time report of the factory solar and my experience with it. It has always been running in the background, but now that we are boondocking at Moab, I've started paying attention to how much power it generates and how we are dealing with it.
My Classic 30 is a 2019. They upped the solar panels to three for a total of 270 watts of power. They also increased the gauge of wire used in the installation and are using Victron equipment. Actually, a pretty nice MTTP controller is installed which I added a BlueTooth dongle to send the date to my phone or laptop.
Today it generated 980Wh of power. At one point, it was putting out 234W! Today started off cloudy or I would have probably gone over 1000W. It is only 5:45 pm and the panels are still generating power.
Last night we turned off all light. I own 2 Acorn LED lights and a Goalzero Lighthouse 250. I'll take some pictures later. They provided plenty of light all evening long. My main batteries (lifelines) started at 12.72. We did not need to run the Alde system for heat last night, only turning it on in the morning to raise the temp from 64 degrees to 70 degrees using propane and electric to run the pump. By then the panels were generating 20W and the batteries were maintained by the 1.2A charge.
By morning my batteries were at 2.64 in the Classic. What was running: Peplink modem/TP router, propane warning, Czone, water pump when needed, various blue LED button lights all over the trailer, and I don't believe anything else. The Czone has a large swich in its system that is powered. Possible the Relax awning curcuit board.
We had pretty good sun today. Bulk was 7h and 15 min. Absorption was 1h and 55m, and float is at 2h and 21m. By the way, we just hit 960Wh!
x\x/x\x/x\x/x\x/x\x/x\x/x\x/x\x/x\x/x\x/x\x/x\x/x
2017 Airstream International Signature 27FB Twin
2019 Airstream Classic 30 Twin
Our Google images and chat: https://photos.app.goo.gl/CMQbpNXQwapMnj8t9
turk123 is offline   Reply With Quote
Old 05-18-2019, 11:28 AM   #2
Mitch
jmitchell's Avatar
Granite Bay , California
Hi! In your second to last paragraph, where your batteries 12.64 in the morning? I’m guessing the 2.64 was a typo.
We are picking up a 2019 30’ Classic on Thursday, and am trying to determine if the factory setup will be good enough to dry camp 5 days at a time without using a generator.
2020 Classic 30RB
2013 2500HD Dmax: 6in lift; Load Range F (3-Ply sides); 1-ton leafs; Hellwig rear sway; Bilstein 5160s
Registered Professional Engineer, CA
jmitchell is offline   Reply With Quote
Old 05-19-2019, 11:06 PM   #3
turk123's Avatar
2019 30' Classic
Canfield , Ohio
Yep, it was a typo. 12.64 was correct. We have run now almost five days on solar. A bit cloudy today, but batteries would have been charged by bright day but we traveled 150 mile and alternator charged fully.
It appears as if with two batteries you can charge with solar to full as long as you have bright light. A sunny day can easily charge by late morning. I built a 300 watt portable system and it looks like i may not need it. The factor here is that you are living day to day with 2 batteries. Four batteries would work much better and lithium batteries would really add to the system.
For me, my generator can fill in on “dark” days. I also am adding a Goalzero Yeti 1000 to avoid using the investor. I am encouraged how well this could change our camping style and saving $30-65 a night in a full hookup campground
Old 05-20-2019, 12:44 AM   #4
turk123's Avatar
2019 30' Classic
Canfield , Ohio
Not "investor" but generator! Tonight we are already at 12.43 V at 10.42 pm. With a full night ahead at running the Alde system, it will be interesting were it will be tomorrow morning.
Old 05-20-2019, 07:32 AM   #5
2019 30' Classic
Wherever I may roam , America
Thanks for posting about your experiences with the Classic 30 stock solar. I have the same unit but haven’t had a chance to put the solar to a real test yet. Looking to do that very soon though. Your posts are helpful!
johnparris is offline   Reply With Quote
Old 05-20-2019, 07:18 PM   #6
turk123's Avatar
2019 30' Classic
Canfield , Ohio
Today started with cloudy and rain. Over the last three nights, we've had less and less solar watts being produced. Overall this last day even though it said 12.72 in the bank, it appears that the battery has dropped faster to 12.19V by morning. I'm not anywhere near an expert on batteries, but it appears that not having the 1000 Solar Watt hours going on during the day, does not fully charge the batteries even though the Victron is reporting the 12.72V. Maybe someone can chime in here.
Today we drove over the Rockies to Denver (4 hours) and fully charged the batteries. We have full hookups at Cherry Creek State Park, so we are off the solar for now.
One observation really surprised me. In Moab, we were facing East/West. I have never before produced the kind of voltage that we got there. Even in Lake Havasu that is ALL sun did I get this kind of production. We also were not in the East/west facing position either.
Our best production was 1.29KW and 1.01 KW. I also got 276W on the Pmax from the 270 watts of panels!
Old 05-20-2019, 08:34 PM   #7
Mitch
jmitchell's Avatar
Great data! The panels should be generating the most while facing south, at ~40 degree angle (depending on month of year, I.e the arc of the sun). They will also be more efficient in cooler weather as long as the UVs are not blocked. Is that consistent with the observations you were describing?
How many KW do you think your producing on the less sunny days, or what do you think may be a reasonable average?
2020 Classic 30RB
Old 05-21-2019, 04:46 AM   #8
2018 30' Classic
New York , New York
We have two batteries left from our 2018 Classic that were not in trailer when salvaged as they were at home maintaining charge over the winter. Dealer has offered to install these in our 2019 Classic for around $500. Is it worth it? Seems reasonable. I assume the existing solar panels will charge more batteries, but would just take longer for all 4 batteries to be fully charged and would double the amount of amp hrs. Is that correct?
ajwbarnard is offline   Reply With Quote
Old 05-21-2019, 08:57 AM   #9
turk123's Avatar
2019 30' Classic
Canfield , Ohio
Airstream has mounted the long panels on each side of the roof and they are angles a bit to the outside. I am assuming that the East/west orientation allows for all three panels to "see" the sun better than a North/south orientation especially when the sun is rising or setting. The skies in Moab are very clear.
On a partly cloudy day, I received 530solar watt-hours with a high of 190-panel max watts. On average 500 WA seems to be the average on partly cloudy days. This does bring the batteries up to 12.7 but does not appear to be as strong a charge as having 800-1000WH feeding the batteries on a very sunny day.
We do not use any lights in the trailer when not using shore power. Especially when we know we will be relying on the Alde system for heat at night. We have 3 lithium battery LED lights that we charge during the day with solar from the roof.
This becomes the discussion of what could be improved and will answer the next post by ajwbarnard. Adding two more batteries I believe is exactly what is needed. On sunny days my battery bank reaches float by late morning. That tells me that an entire sunny day should bring four batteries up to full or almost full. How you add the other two batteries properly to inside the trailer with proper venting in not for me to respond to, but if it can be done, I believe you will have more available power with just using the 270W panels provided from the factory. On top of that, every time you move, your truck will charge them and you still could use a generator during rainy days to charge the bank.
We have not spend a huge amount of time boondocking with our Classic, but we are doing it more and more especially with Harvest host. We are confident in the factory system and I have not had to get out my 300W portable system yet.
Old 05-21-2019, 07:35 PM   #10
Mitch
jmitchell's Avatar
Hi ajwbarnard,
Bay Area Airstream in CA quoted me ~3-4 hours of labor, at 150/hr, to install two additional batteries under the front sofa (not including the cost of the batteries).
I like the idea of having all four batteries under my couch, which will place all four batteries in the same climate, and shift the weight a little closer to the axels. This will also open up the original battery box for additional outside accessible storage which may come in handy. I'm planning to disconnect the original cables but leave them routed to easily return to a factory configuration if desired. I'm hoping to do this on Thursday night (if the project goes easily), but we shall see.
I called Lifeline, since their website says that venting is still required for AGM batteries due to potential venting of hydrogen gas (that's all bad in a confined space). Their technician said that the batteries will only vent if they are over charged (charger fails and continues to charge), or another type of battery failure. He said that the batteries would smell distinctly of rotten eggs if this were to happen which I suppose would provide some warning to vent out the space before trying to light a stove or something. This makes me nervous, even though it seems like most people do not vent interior AGM installations. I'll evaluate on Thursday.
In related news- I'm planning to use 6V Lifeline GPL-6CT which weigh 90lbs each. For this reason I'm changing my Equal-I-zer load distribution hitch to the one which is designed for up to 1,400 lbs of tongue weight. I called Equal-I-zer about this and they advised that the main transfer bar holder is built heavier for this weight rating even though the bars are about the same as the 1,200 model. I also called the Airstream dealership, and their shop manager was not worried about the weight difference as long as the tow vehicle could handle it. I was still less excited about it until I noticed that the 2019 33' Classic already has 289 extra lbs on the tongue than the 30' model (which is more than the extra battery weight will be) and that model also has the primary outside storage up front also. This made me feel better about the weight distribution, especially when that weight will be slightly closer to the axle when under the couch, and with the load distribution system installed for towing. I'll still have to balance out my loading with other objects in the back compartment, but overall it should be just fine.
I'll keep you posted.
2020 Classic 30RB
Old 05-21-2019, 07:41 PM   #11
Mitch
jmitchell's Avatar
Also, confirmed - As you surmised, since you are using 12V batteries all will be wired in parallel, which will double the amp hours available when doubling the batteries. The rate of charge would remain the same, but there would be more "work" to do to recharge the new system if depleted by the same percentage.
2020 Classic 30RB
Old 05-22-2019, 06:53 AM   #12
2019 30' Classic
2012 25' FB Eddie Bauer
Crested Butte , Colorado
Wow, this is a great discussion. I was quoted about $8000 to add five panels to the roof, add a 3000w inverter, and convert to four lithium batteries which is what I had concluded would be required to boondock for a week in my 30. It appears I had a bit of an over design.
jmitchell, why the lifeline AGMs instead of lithiums?
The Alde system makes boondocking in cooler climates possible. A month from now you will need AC in Moab. I wonder how much battery juice is required to run a single AC unit with soft start in the evening to cool a trailer off.
2019 30' Classic RB pulled by 2013 F-150 Eco-Boost Platinum with Max Tow Package
Froglips is offline   Reply With Quote
Old 05-22-2019, 08:13 AM   #13
turk123's Avatar
2019 30' Classic
Canfield , Ohio
One word, GENERATOR! For a $1250 investment in a 2200 W generator and an Easy Start, You can cool your trailer very efficiently. That is what I have. Your front AC in the Classic is more suited to adding the Easystart to as it distributes the cool air better throughout the trailer than the rear AC, but you could add easy starts to both AC to have the choice of which to run. Also, when you do have shore power and only 30 Amp, you can run both AC's without a problem. This is the state of solar and AC right now and is the most practical choice.
I believe if you do run your AC on "solar", you would always be in fear of using all your power up accidentally and getting yourself into bigger issues. Throwing money at 4 lithiums and more panels to accomplish this is just impractical.
Old 05-22-2019, 09:10 AM   #14
Half a Rivet Short
Carlisle , Pennsylvania
Hi
Voltage is not a good way to work out the state of charge on your batteries. It will tell you that you are past 80%, but not if you are at 100%. Since you only run down to 50% that's a long ways. If it's hot out, you need to change all the magic voltages by maybe as much as a half volt to work out what's what.
Mounting batteries under the sofa *does* work. They need to be AGM's or Lithium's. You do not want flooded cells there. You also need to match them to what's outside. That means replacing the batteries you have with new ones ( so they all are from the same batch).
How long you can go depends a *lot* on how much sun / shade you get. In one situation you might get 2KWH in a day. Over the next two weeks you might be lucky to break 500WH a day with exactly the same setup.
A hundred amp hours / 1.2 KWH is a pretty good target for a typical Classic for a day. Being above or below 1KWH matters ....
Old 05-22-2019, 09:51 AM   #15
waninae39's Avatar
2017 22' Sport
NCR , Ontario
IMHO, move to LiOn batteries. they are lighter and greater capacity
we use Battle Born Lion with good results
we move then from outside to inside.
unlike AGM/leadAcid, they do not off gas and are 100% safe to leave inside
unlike AGM/leadAcid, they can go down to 20% unlike the latter that die off quickly at 50%
yes we use a whole lot of victron equipment
waninae39 is offline   Reply With Quote
Old 05-22-2019, 06:10 PM   #16
2019 30' Classic
Charlotte , North Carolina
I have a 2019 Classic as well. Between trips I have been parking on the street in front of our house and running an extension cord out to keep the refer, modem and fant fan running to keep it from becoming an oven.
After reading this I felt like an idiot! Why not let the solar keep the batteries charged and see how it works? So I unplugged it and kept everything else as is. Day 1, all good, nice an sunny. Day 2 was cloudy and I ended up with a warning that batteries were low on the App. So I turned off the fan remotely and the volts started climbing. I watched them climb all day to 12.82v. The low point was 12.2 so it was not really bad yet.
I feel Free! Solar actually works, adds a nice convenience and I can make adjustments remotely if I need to. My one wish is that the App had a 'water pump' status so I could see if I remembered to turn it off.
LilPeanut is offline   Reply With Quote
Old 05-22-2019, 06:54 PM   #17
Half a Rivet Short
Hi
Ok, some numbers for a typical 30' Classic of the "modern era":
Trailer in the "use" mode with the magic electronic system turned on pulls a bit over an amp. Roughly it's 30 amp hours a day.
Fridge running normally also pulls right at an amp. Figure 24 amp hours a day.
Fan on low pulls 1.3 amps, that gets you another 30 or so amp hours a day.
Add that all up and you are at about 84 amp hours.
The two panel solar it doing well at 10A peak. The three panel is doing pretty well at 15A peak. With flat panels and "Northeast" conditions, you are doing well to get 5 hours of "equivalent to peak" in a day. So 50AH with the two panel and 75 with the three panel. In zero shade in the desert, yes, you will do better (like by 1.5X) . In a whole lot of camp sites, you will not make it to those numbers.
With Lithiums whatever the solar puts out, the batteries will take (until they are full). With lead acid, it's more complicated once you get past the 80% charge point.
Lots of fun !!!
Old 05-23-2019, 12:56 AM   #18
Mitch
jmitchell's Avatar
Hi Froglips, I have two of the AGM GPL-4C from my previous trailer that are only a few weeks old, and Batteries + Bulbs will give me full credit back on those if I buy my new set from them which means I would pay the difference of $1,150 to have a new set of four GPL-6C (total of 600AH). The value proposition is very good. I don't think they sell lithiums in the 100AH group, but will confirm tomorrow. Lithiums would be a much better solution for many reasons, which still has me thinking. I'll likely decide tomorrow.
Question: Did your quote include 5 additional panels (total of eight)? I was talking to Lewster (very helpful) on this forum who informed me that our trailers are factory wired with 10gauge from the panels to the charge controller, which depending on the length of run, and acceptable loss, could be at capacity with five 100W panels. I would confirm the 10gauge, but if that is what your trailer has I would make sure the quote included running new wire. It may be a sweet spot to just add two more.
I don't think four lithiums is overkill. That would be 400AH, and assuming you went to max discharge of 20% capacity that would leave you 320AH. User data from this form says to budget at least 80AH per day. That means you could go for ~4 days without solar or a generator if you conserve usage to 80AH. With five solar panels you may be able to charge around 100AH per day (much less in the winter, or shade, and a bit more in good sun), which may equal your average use. Personally that sounds like a good balance to me at 400AH of lithium, and 500W of panel. And you don't need to run new wire for the five panels. I pickup my trailer in the morning and plan to measure actual Amp draw this weekend, and will use that to confirm what sizing I'll need, but right now I'm thinking I'll go to a total of five panels, and either 400AH of lithium, or 600AH of AGM.
Cheers!
2020 Classic 30RB
Old 05-23-2019, 07:06 AM   #19
Half a Rivet Short
Hi
At least the Battle Born Lithiums are a bit different in terms of ratings. They have a built in BMS and it cuts out when they are "to far down". You get at least 100AH to the point it cuts out. They also have tested the batteries for thousands of charge cycles at this level. There is no big reason to only use 80 of the 100 "rated" amp hours.
Dropping four Lithium's into a 30' Classic is not a crazy proposition. Put two in the battery box and two under the center of the recliner. No big mods or chopping required. Yes, two are outside and two are inside. It still works ok. If you plan to use your trailer at the North Pole in winter, disconnect the two outside batteries ....
Wired as four in series (into a 150V rated MPPT) and four strings in parallel, you can get sixteen panels onto a set of 10 AWG wire. If you can find room on the roof for 16 panels ...
JC will put a pair of panels on the roof of a Classic for around $1,600. Battle Born will sell you the four batteries for about $3600 (delivered). A Victron MPPT solar charge converter is < $400, almost no matter which one you get. Pulling wires and bolting things down is very much a DIY level sort of thing .....
Old 05-23-2019, 08:14 AM   #20
2019 30' Classic
jmitchell,
My quote was from Lewster. He is absolutely an expert. My quote was for five additional panels, swapping 10 gauge out for 6 gauge, massive changes in equipment (hybrid converters, etc.), two soft starts, 4 lithiums, etc.
My charter to him was I wanted to be able to boondock for a week with a functional 120v system including AC.
I have a Harbor Freight 3100 generator. It is very quiet and runs one AC and all the 12v stuff for about 9 hours on a tank of gas. While this is a good solution, it means bringing 7 "tanks of gas" on a boondocking trip. Can you say, "Load up the bomb bay."The only safe solution, IMHO, is solar and a large battery bank. If it isn't sunny for a few days in a row then it isn't as hot either. The large number of solar panels are so I can still get some reasonable charging even on an overcast day.
1st post looking at Classic 30 for family adventures ctozzi Trailer Values 0 10-22-2017 11:26 PM
Here we go - the beginning of my solar adventures Bigcgar Generators & Solar Power 28 09-24-2017 07:45 PM
Excellant Adventures :: 1998 Airstream Excella Classic panora2 Airstream Registry Discussions 0 05-29-2013 07:15 PM
Airstream on TLC 9 March and others robandzoe General Interior Topics 60 08-03-2006 09:30 PM
its thursday and to 2airishuman is my favorite goof except the others... Boondocker Off Topic Forum 9 02-17-2006 01:22 PM
