Old 05-26-2019, 10:04 AM   #21
2018 30' Classic
New York , New York
Adventures with Classic 30 Solar (and others)!
So today the power for the campground went out due to someone hitting a utility pole. This is the first time caring about the victron controller monitor. I canít find anything in manual that tells what each reading means. I get the battery level and what kind of charge it is performing. Currently it is bulk charge. What I want know is what the other numbers mean. Is it just the amount of energy coming in in volts, amps, and kWh?
It appears that there is an app to monitor too, but it looks like it needs a blue tooth dongle? Anyone did that? Manual was next to useless.
ajwbarnard is offline   Reply With Quote
Old 05-26-2019, 12:59 PM   #22
2019 30' Classic
Wherever I may roam , America
Maybe this manual will help. Mine did not come with this one. I had to track it down. https://www.victronenergy.com/upload...trol-A4-EN.pdf
johnparris is offline   Reply With Quote
Old 05-28-2019, 04:15 PM   #23
2019 30' Classic
Belleville , Illinois
Turk--pls share the info regarding the bluetooth dongle
Where did you get it and how is it installed. Thanks
Presitla99 is offline   Reply With Quote
Old 05-29-2019, 05:16 AM   #24
2019 30' Classic
2012 25' FB Eddie Bauer
Crested Butte , Colorado
Purchase from Amazon
Download app from Android or Apple app store (Vectron Monitor)
On a 2019 Classic 30', pop off the right lower panel under the hall closet. Look for the blue box, feel around on the left rear of the blue box, you will feel a tiny rectangular plug the same size as the plug on the dongle you ordered. Unplug old plug from back (your gauge behind the range will no longer work), open the app on your phone, plug in the new dongle (it is keyed to only plug in one direction so the fact that you can't see what you are doing is only a minor inconvenience), pair the app and the dongle, RTFM.
2019 30' Classic RB pulled by 2013 F-150 Eco-Boost Platinum with Max Tow Package
Froglips is offline   Reply With Quote
Old 05-29-2019, 07:17 AM   #25
Half a Rivet Short
Carlisle , Pennsylvania
Hi
An alternative is to buy the dongle from PKYS:
https://search-api.swiftype.com/api/...le_p_3796.html
The advantage is that you have Peter to call if there is a gotcha with hooking it up. I also believe that Best Converters is getting into the Victron gear end of things. Same logic, better to have somebody to call.
You *could* also replace the entire solar charger with the "smart" version......
1st post looking at Classic 30 for family adventures ctozzi Trailer Values 0 10-22-2017 11:26 PM
Here we go - the beginning of my solar adventures Bigcgar Generators & Solar Power 28 09-24-2017 07:45 PM
Excellant Adventures :: 1998 Airstream Excella Classic panora2 Airstream Registry Discussions 0 05-29-2013 07:15 PM
Airstream on TLC 9 March and others robandzoe General Interior Topics 60 08-03-2006 09:30 PM
its thursday and to 2airishuman is my favorite goof except the others... Boondocker Off Topic Forum 9 02-17-2006 01:22 PM
