Old 11-02-2019, 08:10 AM   #1
Anywhere , Alabama
AC Turned On-Donít Know Why
Had a weird on last night. 2017 Classic, 2 ACís controlled by one thermostat. Had the AC for both zones in Cool mode (not auto), fan in Auto, temps set at 73. At 1:30 am, with outside temps in low 30ís, rear AC turns on. Checked thermostat and everything looked. Normal. Inside temps for both zones showing 58, so inside was below setpoint and shouldnít have been calling for it to turn on. Had to use ďOffĒ button to get it to shut down. This morning, put everything back to normal and itís fine. Other than a bad dream, thoughts on cause?
Matt & Pam Padgett
Anywhere, USA
2016 Ford F-350 Dually
lukeysh714 is offline   Reply With Quote
Old 11-02-2019, 08:15 AM   #2
Mollysdad's Avatar
Not on "Heat pump"?
or I'd have to do some research into the CCC2 but it can store a program. Perhaps it saw 50's and switched to HP?
Old 11-02-2019, 09:00 AM   #3
Anywhere , Alabama
Originally Posted by Mollysdad View Post
Not on "Heat pump"?
It was showing still on cool mode when I looked at tstat. Iím stumped.
Matt & Pam Padgett
Anywhere, USA
Old 11-02-2019, 10:36 AM   #4
Anywhere , Alabama
Not on "Heat pump"?
It can store 2 programs, but if it is in program mode, an icon will be visible,,,,,,no icon.
Matt & Pam Padgett
Anywhere, USA
Old 11-02-2019, 11:05 AM   #5
Half a Rivet Short
Carlisle , Pennsylvania
Hi
In heat pump mode it (obviously) goes through a de-ice / cold weather process. There may be some magic code in there to do this once every XX hours, regardless of the mode if the temperature sensor says it's cold out.
Old 11-02-2019, 12:54 PM   #6
dznf0g's Avatar
Oswego , Illinois
Hi
I think it is a simple high pressure switch signal that activates the reversing switch. No magic. Just chemistry and physics.
-Rich-
Old 11-02-2019, 01:35 PM   #7
Anywhere , Alabama
Wasnít on heat pump and wasnít supposed to come on because temps werenít calling for it.
Matt & Pam Padgett
Anywhere, USA
Old 11-02-2019, 01:55 PM   #8
dznf0g's Avatar
Oswego , Illinois
Originally Posted by lukeysh714 View Post
Wasn’t on heat pump and wasn’t supposed to come on because temps weren’t calling for it.
I was commenting on Uncle Bob's post.
Try going through the reset procedure. I am not a CCC2 expert, but have had to do this on my Brother-in-Law's once or twice for various strange anomalies. I've had to reset my CCC1 a few times as well. Back when I used the store switch a lot, it seemed to have strange behavior occasionally, when powering back up. Now that I have solar on the roof, I don't put in store anymore.
-Rich-
Old 11-02-2019, 01:58 PM   #9
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Don't forget Zone1 and Zone2.
With 2 air conditioner you might have had Zone 2 on AUTO or HP and Zone 1 on Cool.
A low enough inside temp would have triggered the second zone to turn on heating in either case.
Old 11-02-2019, 02:05 PM   #10
Anywhere , Alabama
Nope. Both zones on cool set to 73. Thatís why Iím stumped. It was cold here so wondering if a drop of condensate got across two circuit board circuits and simulated a turn on command. That happened to our firefly lights in living room area once.
Matt & Pam Padgett
Anywhere, USA
Old 11-02-2019, 05:33 PM   #11
Mollysdad's Avatar
As a side note, when I got my AS, it was recommended to NOT set both A/C units the same. Why? So they don't cycle on and off together. I'll set the main one to 73 and the second unit to 75.
That way one comes on to keep the temperature at 73 but if it gets too hot, both can come on at different times.
Old 11-02-2019, 05:49 PM   #12
2020 Classic 33 on order
Box Elder , South Dakota
Shouldn't be any issue if they cycle on and off at the same time. They are on different legs of your 50 amp power line. Assuming you have 50 amp.
Gary
2020 Classic 33 Twin, 2019 Ram 3500 Longhorn, ProPride
NōVPN
ghaynes755 is offline   Reply With Quote
Old 11-03-2019, 07:11 AM   #13
Half a Rivet Short
Hi
The only time you *really* need both units is when it's really hot (or really cold) in the trailer. When that's true, you most certainly want both on at the same time. They will time out based on the thermostat. Normally one end (the bedroom area in our case) beats the other to temperature by a fairly wide margin.
Old 11-03-2019, 10:22 AM   #14
CruizinDux's Avatar
Tracktown USA , Oregon
X2 on the reboot. It's in the manual.
On our maiden apparently i switched fan frim outo to low. Next morn switched on the furnsce and the AC fired simultaneously.
Reboot suggested on forums fixed issue. Apparently CCC2 has a history of these idiosyncrasies.
B
CruizinDux is offline   Reply With Quote
2008 Ocean Breeze - plugged in, turned a/c on - turned off - Wonít turn on again samiam8888 Furnaces, Heaters, Fireplaces & Air Conditioning 0 07-04-2018 10:14 AM
Why, Why, Why aviontt On The Road... 22 11-20-2003 08:41 PM
I don't know where to begin - part I susie Our Community 6 09-24-2002 09:26 AM
