04-23-2018, 05:03 PM
2018 30' Classic
Bothell
50 amp 90 degree adapter
My 50 amp power cable sticks straight out from the side of the Airstream. I am a bit concerned about the stress of that heavy cable on the connector.
Anyone using a 90 degree adapter cable to bring the power cable down the side of the Airstream?
Saw a couple on Amazon but several individuals indicated that once they plug the 90 degree adapter into their trailer, twist to lock, it is anything but pointing down towards the ground.
Thanks.
Chuck
04-23-2018, 06:22 PM
2017 27' Flying Cloud
Fort Worth
Thanks.
Chuck
If you are using the cable that comes with the Airstream, consider buying a new one at Etrailer.com. They have several that will coil into a 1' diameter coil and come with a 90 degree end. They are about $165 but much easier to use.
04-23-2018, 06:40 PM
Tampa
Yes. After my first trip, I ditched the awful OEM cable and got this.
04-23-2018, 06:50 PM
The Panhandle
, Idaho
Marinco 90 Degree Adapter
I too was concerned about the stress the heavy 50 amp cord was putting on the side wall of the trailer and the connector itself. Looking on the inside where the connector penetrates the skin I was not overly impressed with the amount of support provided. Lifting the factory cord to take the weight off the connector you could actually see the exterior skin flex.
So I added some plywood backing on the inside and also purchased the Marinco 90 degree 50 amp adapter off Amazon. I chose the Marinco unit after reading the reviews on "the other model" and seeing the same comments about the adapter not hanging straight down.
I am very pleased with this Marinco product as I have been with previous products of theirs I have purchased for boating. Very good quality and it hangs straight down once twisted on.
To do it over again I'd buy the 25 foot cord from etrailer. It's just a little over twice the cost of the Marinco adapter and their cord coils much easier and into a smaller coil. What to do with the factory cord? Either leave it in place if you have your trailer plugged in at home. Or replace the female end and turn it into a 50 amp extension cord.
Hoagie '59
Hoagette '57
Whitney and Tobin -- The Aussie Posse
04-24-2018, 08:34 AM
2018 30' Classic
Bothell
Thanks. Looking at both options.
Chuck
04-24-2018, 02:24 PM
2004 30' Classic
Johnson City
Consider replacing the connector and cable with SmartPlug. We filled the space between the aluminum skins with a marine semi-hardening foam. Four #10-32, 3" long stainless steel screws hold all in place nicely. Have fender washers and locknuts on the inside skin. See no deflection of outside skin during connection or disconnection. SmartPlug is solid!
The image shows the SmartPlug just forward of street side wheel well. Image also shows the NEC 551.46(D) warning label.
Gus - KR4K : Mary - K5MCL
2004 30ft. Classic
2017 Infiniti QX80 Limited
ProPride 3P/Prodigy P3
04-24-2018, 03:42 PM
Firedog1
2018 30' Classic
Woodbridge Connecticut &
, Venice Florida
Mighty Cord 90-Degree Detachable RV Power Cord w/ Locking Ring and LED - 50 Amps - 25' got it today on e-trailer.com $157. No more fighting with the anaconda.
Russ and Lisa
2018 Classic 30
2020 GMC Sierra 3500HD Denali Diesel 4x4
Sold but not forgotten: 2005 Classic 25 Limited
2015 Classic 30 RB
04-24-2018, 05:21 PM
2023 23' International
Macon
, Georgia
I did the same, the only problem is etrailer said they are out of stock and it won't ship until the end of May...Shucks another month fighting the anaconda...
04-24-2018, 11:39 PM
2017 27' International
Fall City
Just ordered this myself. I need to stop reading these forums.
2017 27FB International
2013 Ram 2500 Laramie Crew Cab CTD 4x4
04-25-2018, 03:36 PM
PSU1981
2015 27' Flying Cloud
Conroe
Just ordered one also... Reading Forum = spending $
04-25-2018, 05:15 PM
2014 27' FB Classic
Cambridge
, New York
OK, so I'm a cheapskate. I just took a 1" x 3" about 3' long, cut a "V" into one end, and brace it against the ground and bottom of the tire at a 45 degree angle for support and take the weight off the plug. Not wrestling the anaconda sounds tempting, though...
"Hot meals, cold beer, dry bed & flush toilet - everything I look for in a wilderness experience..."
04-28-2018, 03:36 PM
2018 30' Classic
Jacksonville
OK............unless the angle of the prop just changes the vector of "weight" forward instead of down.
04-28-2018, 11:29 PM
2014 27' FB Classic
Cambridge
, New York
It seems to take the weight off the plug receptacle itself, as there is no more sag to the plug or flex in the receptacle or skin around it - which is what precipitated my decision for a cob-job quick fix...
Not perfect, but I think it lessens the stress on the receptacle better than just a 90 degree plug, which still has the weight of the plug and lead hanging from the receptacle unsupported.
05-06-2018, 04:15 PM
2018 30' Classic
2004 30' Classic
1972 Argosy 22
Meridian
, Idaho
Another option is this Camco "extension cord" (misnamed). It has a 90 degree female 50A to connect to the trailer and a 50A male for park power.
https://www.amazon.com/Camco-Extensi...extension+cord
Current cost is $115. 10 days ago I paid $98 Prime. It works great. The coach end connects with a straight down connector. The handy dandy carrying strap is a nice bonus.
It is much more pliable at colder temps than the Airstream provided "snake".
Charlie
05-06-2018, 04:49 PM
2017 30' International
Broomfield
Highly recommend this bad boy, per the poster above. Money well spent and it’s much more flexible than the standard grey 50A monster......
