Old 12-02-2019, 04:00 PM   #1
2020 30' Classic
Blue Ridge , Georgia
30' classic rb twin
Am I missing something? The shelves for the medicine cabinet won't stay where there suppose to. Is there some trick to secure them in place? Tape/ Screws?
Gleverett is offline   Reply With Quote
Old 12-03-2019, 05:15 AM   #2
JDG
Riveted
JDG's Avatar
2018 33' Classic
Charleston , West Virginia
I have a 33 but I assume the shelves are the same. I removed the shelves but left the metal brackets the shelves sit on in place. Placed a small dab of silicone sealer on each bracket and placed the shelf back onto the brackets. Problem solved. I think this idea is on a thread somewhere. I also took wooden dowel rods, stained them to match cabinetry, and inserted them into the holes above the shelves (where the brackets would go if you raised the shelf). This holds the items on the shelf in transient and prevents them from falling out when you open the door after traveling. There are pictures in of this mod in one of the threads. Good luck.
JDG is offline   Reply With Quote
Old 12-03-2019, 05:26 AM   #3
JDG
Riveted
JDG's Avatar
2018 33' Classic
If you do a search for “suggestions for medicine cabinet storage” I think you can see the pictures. Eventually I found a stain to match better. Looks like it was that way from JC. Also applied Airstream’s pressure sensitive gray liner on the top portion of a couple of shelves which prevents things from sliding around so easily.
Old 12-03-2019, 05:45 AM   #4
Sarasota , Florida
We have a 2020 FLYING CLOUD and we found the perfect bins at Target. They are small and tall enough to fit in the small bathroom closet that I’m assuming you are referring to as the medicine cabinet. They’re nice because each individual item isn’t sliding around in the cabinet. It’s all contained in a small bin. Plus, if something leaks it’s going to leak in the bin and not all over the cabinet! Just take the bin out, use the products you need then put the bin back. This works perfectly for us. (The bins come in opaque white or opaque grey and are located in the bathroom towel/waste can section of Target),
TontoFC is offline   Reply With Quote
Old 12-03-2019, 07:40 AM   #5
Half a Rivet Short
Carlisle , Pennsylvania
Hi
Clear silicone RTV "glue" from your local big box store on the shelves at the support tabs does the trick pretty well.
uncle_bob is online now   Reply With Quote
Old 12-03-2019, 12:31 PM   #6
1996 25' Excella
Tillsonburg , Ontario
2017 Bambi ...same issue
JCW
JCWDCW is offline   Reply With Quote
Looking for a Trade-Up opportunity. 2015 27' FC Twin to 2017 30' Classic Twin santaman Airstream Classifieds 0 04-14-2019 08:16 PM
Modified Rear Twin from 2-34" Wide to a 34" and 39"STD Twin sgschwend General Interior Topics 5 11-12-2016 09:45 PM
2 rear twin mattresses from a twin to full conversion. jgp1968 Airstream Classifieds 0 09-08-2014 12:15 AM
To twin, or not to twin? That is the question switz Airstream Lifestyle 27 08-09-2013 09:42 PM
