Old 11-09-2019, 04:46 PM   #1
2020 33' Classic
DFW , Texas
2020 Classic 33 Microwave Not Working
This morning the microwave was working. 500 miles later its not. Reset breaker. Still no power to microwave. I feel as though its plugged into a GFI that tripped. Or the plug came loose (but I cannot find it :-(
Any suggestions to locate the problem?
BTW, Bose sound bar also has no power but other all outlets do have power...
no_worries is offline   Reply With Quote
Old 11-09-2019, 05:27 PM   #2
BigSxyWhtGuy's Avatar
2018 30' Classic
Thousand Oaks , California
Are you on shore power? No other tripped breakers? Usually if a breaker trips there are some that can only be reset by being on shore power
BigSxyWhtGuy
Follow our adventures!
@airstreamvagabond on Instagram and YouTube
BigSxyWhtGuy is offline   Reply With Quote
Old 11-09-2019, 05:42 PM   #3
Half a Rivet Short
2017 30' Classic
2022 Interstate 24X
Carlisle , Pennsylvania
Hi
Normally (it's an Airstream ... there is no normal ...) the plug is behind the microwave. You have to pull the unit out of the cabinet to get to the plug.
uncle_bob is offline   Reply With Quote
Old 11-10-2019, 03:32 AM   #4
2020 33' Classic
DFW , Texas
On shore power and no breakers tripped (have reset all, just in case). Will pull microwave today.
Old 11-10-2019, 04:41 AM   #5
Sag Harbor , New York
The outlet behind/near the microwave may be a GFI, which you will have to reset. Is the breaker for this circuit not a GFI breaker? If so, there may be another nearby duplex outlet which is a GFI, which in turn supplies other outlets like the one for the microwave. Reset all GFI breakers you can find, including the in the bath. [ . . . cover all the possibilities . . . . . . ]
Good luck,
Peter
Old 11-10-2019, 10:45 AM   #6
HankO's Avatar
1997 28' Excella
Eden , Utah
Voltage Tester
I always carry a Voltage tester with me. Will tell you immediately if the plug has power or not.
https://www.homedepot.com/p/Klein-To...2SEN/203499607
HankO is offline   Reply With Quote
Old 11-10-2019, 03:29 PM   #7
2020 33' Classic
DFW , Texas
Thanks everyone. After pulling the microwave, I found the cord had work its way from the outlet. Problem solved.
For future reference, I think pulling the drawer from under the microwave may be an easier pathway to the cord/outlet as the cord on the microwave is barely long enough to reach the outlet when the microwave is pulled out.
Old 11-10-2019, 04:12 PM   #8
Thanks for the update.
Case closed!
Old 11-11-2019, 07:51 AM   #9
Half a Rivet Short
2017 30' Classic
2022 Interstate 24X
Hi
At least on my version of the Classic, there is a solid partition between the drawer and the microwave section. It runs back far enough that getting to the plug via that route is not an option. It's Airstream so who knows what this or that trailer may have in it .....
2020 Classic 33 AC Vents are not removable ghaynes755 2016 - Current Classic (all lengths) 11 07-22-2020 10:18 PM
Front interior light not working, middle and rear working? jonnyo Lights - Interior & Exterior 5 01-06-2020 11:25 AM
Comparison... 2016 Classic - 2019/2020 Classic PamK53 2016 - Current Classic (all lengths) 17 10-18-2019 08:23 AM
Electic Jack not working - fuse good - manual not working ryandanz Jacks, Stabilizers, Lifting and Leveling 20 04-24-2016 10:04 AM
Microwave not working ViewRVs Airstream Motorhome Forums 4 08-28-2002 02:08 PM
