Old 09-18-2016, 12:25 PM   #71
BAB
BAB's Avatar
2015 30' Classic
2012 28' International
Greensboro , North Carolina
Gary...that was an AMAZING articulation of how the sail switch works (well, is supposed to work). I remember you had this issue when you first got your trailer. Mine was working fine. Until all of a sudden it would start up, light and then cycle off (and on) and off (and on). I knew immediately what it was as we'd talked about this on the phone. After I removed the outer cover I was able to remove the two small screws on the sail switch, carefully pull it out of the squirrel cage fan housing and do a bit of minor bending. It took my about 30 minutes to get it into the right shape...but it worked fine up in Maine a few weeks ago. Another example of how beneficial AirForums can be if folks share the "what happened to me" stuff. Barry
_________________
"SilverLeaf II" 2015 30' Classic
2014 RAM 2500 Laramie 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
BAB is offline   Reply With Quote
Old 09-18-2016, 10:06 PM   #72
2016 30' Classic
Erie , Colorado
If you buy a replacement it ships with a plastic "slip" cover that will allow you to bend your original back into shape. I found that the replacement had a thicker arm than the original. Wondered if the original was simply to thin. DH, yes I had this issue. Did everything else first, new control board, adjusted the igniter/sensor arms (gap was to wide). Be careful working on this as it is easy to crack the ceramic base (throw away at that point). Checked the pressure from the tank pressure regulator. It was a bit low, replaced with a better regulator. Still had the start/stop issue. Last item was the sail switch. Bingo and haven't had a single issue since. Camped at 10,000 feet down to sea level without any problems.
Gary
2015 Classic
2015 GMC Sierra 2500HD Duramax
ProPride
NVPN
ghaynes755 is offline   Reply With Quote
Old 09-24-2016, 01:01 PM   #73
dennis3751's Avatar
1976 29' Ambassador
Fitchburg , Wisconsin
2016 Classic
One other thought on furnace not firing up. If the DC system is below 12 volts or so the fan won't turn fast enough for the sail switch to operate. Well charged battery or hooked up to 120 AC is important as well.
Dennis
dennis3751 is offline   Reply With Quote
2016 AlumaFandango 9/20-25/2016 Glenritas Other Rallies & Events 14 09-26-2016 10:40 AM
2016 classic water leak! Sjcjr Plumbing - Systems & Fixtures 2 08-29-2016 01:33 PM
2016 Classic with shades of lemon Amaranto General Repair Forum 133 07-13-2016 06:28 AM
2016 Classic questions, options, etc Boogieshoes 2016 - Current Classic (all lengths) 114 11-30-2015 07:10 PM
2016 AlumaFandango 9/20-25/2016 Glenritas Other Rallies & Events 2 10-26-2015 05:57 PM
