01-21-2019, 10:29 AM
Merriam
, KS
12V electrical not working... temp 20 degrees!
I have a 2017 Classic 30. It's new to us, so the problem might be me! I apologize in advance for the long post- but I've really tried hard to figure this out...and I'm stumped.
Plugged into 120V, 20amp circuit at home... for about a week. Everything seemed to going fine. The weather has been 20-40 degrees the whole time. Alde system set at 47 degrees. We are not winterized.
We were giving a friend the nickel tour yesterday, and noticed the Alde system screen said "Battery too low." The inside temp was 42 degrees. The batteries were at 9.9V. I hooked up to the TV and the display indicated 11.1V and was climbing. At this point I suspected the onboard charger/converter wasn't working. I read everything I could find on this forum and Facebook. I also thought there's a possibility that the batteries are shot and/or the charger just can't keep them up or is shot. So....
I checked the batteries and several cells needed fluid. So I added distilled water. I put an external charger (set a 3 amps) overnight hooked directly to the batteries. Everything seemed to be heading the right direction as I checked on things several times last night. The display in the AS said 11.9V, and then at the last check 12.8V. So I quit worrying so much.
BUT.... this morning, batteries at at 100% charge at 12V (according to my charger- which automatically stops charging when full). But nothing on the 12V side is working in the AS. 110 outlets are working (still plugged into 120V 20A circuit through the shore line). It's currently 26 degrees inside, and 23 degrees outside. The backlighting for all the control panels are flickering. No lights will come on. So I put a space heater in there for the time being, plugged into an outlet in the bathroom and opened all the cabinets. Hopefully I haven't popped any plumbing.
The battery disconnect switch by the door is on. I know the Alde control operates on 12 volt (even though the elements run on 120V). So I understand why the Alde system isn't functioning. All the breakers are "on." I even flipped them all off then back on. All of the 12V breakers are normal. The two 30 amp fuses on the Converter/charger are good, too. The main screen by the dinette where I normally look for battery condition isn't lit... so I looked under the sink at the battery/tank monitor and it says "6oo" ...which kind of looks like "Boo" in LCD-speak ...no doubt a reference to my performance in this endeavor
I did notice that the little red light on the AS end of the 50A cable isn't lit- but that might be a coincidence or unrelated.
Is the Converter/Charger shot?
Are the batteries shot?
Are both shot?
Did I fry something charging the batteries overnight without isolating them?
Hoping for some wisdom.
Doug
01-21-2019, 11:14 AM
Merriam
, KS
Update.... I disconnected the batteries from the AS and checked each with a multi-meter. They are at 8.07VDC and 8.3VDC. So I'm starting with the bad batteries theory. I know that's not enough juice for life, but explains the flicker of life I saw.
And after charging all night, and that they had dry cells, I'll start there. Maybe the converter/charger is bad too. We'll see what happens with good batteries. But since everything is close for the holiday, will have to shop for batteries tomorrow.
01-21-2019, 11:27 AM
2018 28' International
Fayetteville
, Georgia
If your batteries went dry, they are likely damaged. Time for replacement.
brick
2018 International Serenity
Cute wife...
01-21-2019, 11:43 AM
1988 32' Excella
Ojai
Clean the terminals and put them back on the charger. Maybe they will still hold a charge long enough for some testing. You can always get new batteries tomorrow.
Dave & MJ
1988 32' Excella 1000 (Beauty)
1999 White Dodge SLT Laramie 3500 Dually, 4x4, 5spd, 5.9 CTD 300k+ (The Beast)
01-21-2019, 11:46 AM
Merriam
, KS
I've got no way to load test. I'm at interstate battery now. I'll have them charge and test them, and go from there. Thanks for responding!
01-21-2019, 11:52 AM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Welcome Aboard!! 🥂👍
First thing I would do...leave the AS plugged in and WINTERIZE.
Get some more heaters in there and say a little prayer to Wally that nothing has frozen.
It's not likely to warm up much in Kansas 'til Spring.
You can remove the batt's to charge & test, if the converter is good everything will be powered in the AS.
Interstate checking?...A quick charge and test?
Pay the pro-rate and accept new batts.
Good Luck...🤞
01-21-2019, 12:12 PM
I'm In
, Kentucky
If you have no 12 vdc in the AS when on shore power, then something has to be amiss with the converter. Even without batteries, if you are on 110 vac then the converter would be supplying 12 vdc, even if not charging the batteries.
The Use / Store switch by the door has to be in the Use position for charging. If you are plugged into 110 vac the red light will be on and you should have 12 vdc inside, but press the switch to Use to be sure you're charging the batteries.
...even so, when connected to shore power the converter should be providing 12 vdc. You should have winterized, at least use an air compressor to blow out the lines.
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE 4.7L V8
01-21-2019, 01:27 PM
Merriam
, KS
Good Luck...🤞
[emoji631]
We're going right back or in it soon....so I was hoping to avoid all that....but even blowing out the lines as you suggested would provide peace of mind when something fails.
01-21-2019, 01:32 PM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Exactly Doug...blo 🌬 and leave all drains and faucets open.
Hope all is OK...👍
01-21-2019, 01:34 PM
Merriam
, KS
I was thinking the 12VDC power still comes from the batteries even when plugged into shore and the converter/charger is keeping the batteries operational. I know when I removed the batteries today, there was no 12VDC even when plugged into shore.
If I understand you correctly, are you saying the converter/charger supplies 12VDC instead of the batteries when plugged into shore?
Interestingly, with no batteries in the AS, I plugged in the TV and everything worked great... 12VDC, 120VAC...all worked great.
01-21-2019, 01:56 PM
2002 25' Safari
Dewey
When you plugged in the TV you were supplying 12 volts via the charge line from the TV to the trailer. It sounds like you might have a failed converter.
Richard
01-21-2019, 02:42 PM
Merriam
, KS
Update: Interstate read the batteries their last rites. Replaced them, along with a small pro-rate. Installed them and everything is working. Initially, the display by the dinette said 12.4VDC, which concerned me a little. I couldn't tell if the converter was running or not when I stuck my head down there to listen. So I ran an errand... and when I returned in 15 minutes, the display showed 13.7VDC. This is good!
Oh- my little space heater brought it up to 40 degrees inside
Can I reasonably deduce that the charger is working, and the batteries were shot? Problem solved?
01-21-2019, 03:28 PM
2002 30' Classic S/O
Fleming Island
You are a few days away from another set of bad batteries
In my opinion, no! With the batteries removed and plugged into shore power, everything 12V should have been working, just like it did when you plugged in the TV. Either your converter is bad and not supplying power or there is a bad connection, fuse, or circuit breaker that is keeping the converter power from getting to the trailer circuits and batteries. This is what killed your original batteries.
If you have a meter, disconnect the batteries and start at the converter following the wires until you find the place where you don't have 12V. There may be fuses on the converter itself.
Al
01-21-2019, 03:50 PM
2019 27' Globetrotter
2023 30' Classic
Denver
, North Carolina
"I did notice that the little red light on the AS end of the 50A cable isn't lit- but that might be a coincidence or unrelated".
It is unrelated, it only lights up if you are connected to 50 amps and the power is making it from the pedestal to that trailer end of your power cord.
Can't give you any better advice than you've been getting on your bigger issue. Good luck.
Dave S
01-21-2019, 03:55 PM
1988 32' Excella
Ojai
Do a simple test. Unplug from shore power and see if the voltage drops to 12.8v or less. Then plug it back in. It should go back to 13.7v. 13.7v sounds like it is charging, but you will know for sure in a 15 min.
Dave & MJ
01-21-2019, 04:14 PM
Merriam
, KS
Before I unplugged it from shore, it read 12.5VDC. I turned the battery disconnect off, then back on. I unplugged shore power and 12.5VDC remained. Plugged shore power back in and still at 12.5VDC. No noise from the converter/charger. I'll pull it out and look for any obvious loose confections. Beyond that...I'm sure I'll have more questions.
01-21-2019, 05:39 PM
Merriam
, KS
Pulled panels and checked voltage everywhere while plugged into shore and when not. All seems as it should be in places I checked. The converter is receiving 118VAC (as measured). The three terminals on the front of the charger read 12VDC. No loose connections that I found, including grounds.
A couple of you indicated that the 12VDC side should work if plugged into the shore line WITHOUT BATTERIES. Am I getting that right? Seems counter-intuitive to me....but I guess that's why it's called a CONVERTER/charger....and not just a charger.
At this point, and based on a plethora of recommendations on this forum to do so anyway, I'll replace the converter/charger with a multi-stage boondocker.... Unless there's something else for me to try...???
01-21-2019, 05:53 PM
Merriam
, KS
...and after thinking some more....
Am I just reading 12VDC on the terminals on the front of the converter/charger because I'm still hooked up to batteries, and I'm just reading them, and not the function of the converter/charger? If so, I'm still not testing the 12V side of the converter's capability to run the 12VDC side of the AS without batteries.
How do I test the converter/charger output for the shore line operation only?
01-21-2019, 06:11 PM
1974 Argosy 26
Morrill
, Nebraska
Does the converter have 120 volt AC power to it?
Is there a 120 volt circuit breaker tripped.
What is the output voltage of the converter without batteries connected?
01-21-2019, 06:37 PM
Merriam
, KS
Converter has 120VAC (measured in the wire after the breaker...so the breaker is not tripped).
I turned the battery disconnect switch off and the three terminals on the front of the converter/charger read 11.3VDC.
Then in addition, disconnected both batteries. The three terminals on front of the converter/charger read 4.3VDC.
But I'm not even sure if that's where the output voltage of the converter is measured.
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Help! Electrical not working on 12V
July |
Electrical - Systems, Generators, Batteries & Solar |
15 |
11-30-2019 02:00 PM |
Electic Jack not working - fuse good - manual not working
ryandanz |
Jacks, Stabilizers, Lifting and Leveling |
20 |
04-24-2016 10:04 AM |
Dual A/C still not enough in 90 degrees, sun, wind, humidity?
Jammer |
Furnaces, Heaters, Fireplaces & Air Conditioning |
30 |
06-17-2014 11:07 AM |
Thermostat reading -05 degrees inside temp
CJBrent |
10 |
03-11-2013 12:45 PM |
Interior temp gauge not working...anyone seen one of these?
3campers |
General Repair Forum |
7 |
10-29-2012 04:45 PM |
