The wire you are looking at is the power lead for the roller tube motor, if the awning fails in the extended position, disconnect here and use a jumper (provided by Zip-Dee) to retract the awning. These are great awnings that have a bad reputation. They will collect a lot of water if left out when raining and then will destroy the fabric, if using the "tilt" to drop the front or the rear, do NOT try to "close" from this position, always raise the tilt before closing. That's it, if you have trouble just call Zip-Dee, they are a small company, but really nice people who will help you with everything!
