Old 09-02-2019, 10:12 PM   #1
2017 27' International
Dadeville , Alabama
Windows on 2017 Serenity
When opening the windows, you have three different positions available. I would like to keep mine open especially at night in the first position. The windows just won’t stay open for me in that position, and if I should get them opened in that position a gust of wind or opening the door might cause them to close. Is there any adjustment or trick anyone might have that could help. Thanks
Dlat is offline   Reply With Quote
Old 09-02-2019, 11:00 PM   #2
mikeinca's Avatar
2018 30' Classic
Santa Rosa , California
I've not found a way to have them stay open in position one either and there's no adjustment that I can determine. I'll be interested to see if someone has come up with a clever solution to the problem.
“The good thing about science is that it's true whether or not you believe in it.”
― Neil deGrasse Tyson
2018 30' Classic Twin (sold)
2020 25' Globetrotter Twin (inbound)
2017 F250 4x4 6.7 max tow Platinum
mikeinca is offline   Reply With Quote
Old 09-03-2019, 06:02 PM   #3
VaTravelers's Avatar
2017 28' International
Virginia Beach , Virginia
We have a 2017 28' Serenity and do not have a problem keeping our windows open in the first position. I wonder what the difference is in the window adjustment track might be. I'd be interested in hearing if others are having this problem.
VaTravelers is offline   Reply With Quote
Old 09-03-2019, 06:06 PM   #4
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
Here is the fix:
1. Open the window to position 2 or 3
2. Go outside and walk around to the open window
3. Remove your sock from your foot
4. Roll-up said sock
5. Place rolled-up sock against lower part of screen / window frame
6. Go back inside
7. Close window so that it is propped open by sock
8. Enjoy the fresh air!
wulfraat is offline   Reply With Quote
Old 09-03-2019, 06:09 PM   #5
Lost in America
mojo's Avatar
2015 27' FB International
2004 19' International CCD
Santa Fe , New Mexico
Is that a clean sock or used?
This is the strangest life I've ever known - J. Morrison
2015 Airstream International Serenity 27FB
2017
Chevy Silverado 2500HD Duramax Diesel
mojo is offline   Reply With Quote
Old 09-03-2019, 06:20 PM   #6
wulfraat's Avatar
Aroma = ((time on foot) * (time since last shower)) /(amount of soap used expressed in grams)
As the above value asymptotes on its way towards infinity you may want to choose an alternative method.
Hey it’s camping!
Old 09-04-2019, 09:44 AM   #7
2016 25' International
Williams , Oregon
I have had this problem occur also. Tighten the window arm hinge fasteners a bit and they will then stay open on the first position. They may loosen again with use but The fix will be the same.
MooseAir is offline   Reply With Quote
Old 09-04-2019, 09:52 AM   #8
2018 27' International
Glen Allen , Virginia
My dealership said it’s an incorrect installation and the brackets need to be moved up a little. I’m taking my 2018 to the mothership in November for a few warranty items and that is one of them. It’s all of the windows on the passenger side. The one drivers side window in the bedroom works fine.
Vapilotda is offline   Reply With Quote
Old 09-04-2019, 09:54 AM   #9
2019 27' Globetrotter
Salem , Oregon
The best fix would be for Airstream to figure out a better to open/close them that can be adjusted from 0 to all the way with a crank. That would also allow you to open them with out a credit card and spray.
Dave
NoResults is offline   Reply With Quote
Old 09-04-2019, 01:51 PM   #10
Dadeville , Alabama
Thanks for info. Socks are definitely out. I ‘ll tighten hinge arm if that doesn’t work I’ll stick at popsicle stick in it.
Old 09-04-2019, 02:34 PM   #11
2019 30' International
Pennsylvania , Pennsylvania
You can open the latch to vertical and let the window rest on that.
Or have the side brackets raised at the factory.
It's a common issue, I dealt with it on our '19. Seems the technicians at the factory can't mount the brackets properly. Go figure.
If you ain't havin' fun you ain't doin' it right
2017 Ford CCSB F250 XLT 6.2L Gas 4x4 Ruby
2019 International Serenity 30 Rear Twin
majorairhead is offline   Reply With Quote
Old 09-06-2019, 07:22 AM   #12
1972 25' Tradewind
1976 31' Excella 500
Denver , Colorado
The side brackets that the support arms rest in need to be adjusted (moved up). I was surprised to find that moving them even a quarter of an inch can be the difference between a window that flops closed and one that stays open in first position (it will also make getting them open easier).
25' 1972 Airstream Trade Wind Land Yacht
2006 Jeep Liberty CRD (diesel)
http://BeahmStream.com
kidjedi is offline   Reply With Quote
2011 Airstream 27FB Serenity LIKE NEW!!! S2011 Airstream 27FB Serenity LIKE NEW!!! eBay Watch Airstreams on eBay 0 08-19-2011 02:00 PM
2011 Airstream 27FB Serenity LIKE NEW!!! S2011 Airstream 27FB Serenity LIKE NEW!!! eBay Watch Airstreams on eBay 0 08-12-2011 01:50 PM
2011 Airstream 27FB Serenity LIKE NEW!!! S2011 Airstream 27FB Serenity LIKE NEW!!! eBay Watch Airstreams on eBay 0 08-05-2011 09:50 AM
2011 Airstream 27FB Serenity LIKE NEW!!! S2011 Airstream 27FB Serenity LIKE NEW!!! eBay Watch Airstreams on eBay 0 07-29-2011 09:40 AM
Windows, windows, windows... Balquin Windows & Screens 4 07-04-2006 06:35 PM
