Old 02-16-2018, 12:07 PM   #1
2018 25' International
Menifee , California
Window lever knobs for our 2018 Intíl
Every time we open the windows- hold the little square knobs on the lever poles- we accidentally pull them off or they turn because they arenít attached; theyíre just slid on, not screwed on or tight. Is there a little screw used to tighten them on thatís possibly missing?
Reeltimer is offline   Reply With Quote
Old 02-16-2018, 01:15 PM   #2
2017 23' Flying Cloud
Okatie , South Carolina
I just used red Locktite and put a generous amount in the handle and slid on the metal lever. All mine were easy to remove - too easy. I'm sure super glue or such would also work but Locktite is easy to use and possibly easy to remove handle if ever necessary. All my window seals stick if not used for a week or two causing a great torgue on the handles. There are no screw used on any Airstream of late I have observed. This took care of my problem. Airstream recommends olive oil on the seals - I have mixed results but seem to do no harm.
Martinod is offline   Reply With Quote
Old 02-17-2018, 06:02 AM   #3
Thanks for that. It's just a little annoyance when we aren't paying close attention while opening the windows. And since our AS has been parked for long period of time (that's another story), in Southern California, our windows do stick- so thanks for the reminder of applying a little olive oil to the seals, that will help.
Old 02-17-2018, 06:24 AM   #4
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
We ordered chrome metal knobs from Vintage Trailer Supply and used some locktite on the set screw to hold them in place.
https://www.vintagetrailersupply.com...-p/vts-294.htm
We were able to install these spring loaded window push to open buttons in our 2015 23D International Serenity but they would not work in our 2014 Classic.
http://www.seeyoudowntheroad.com/window-poppers/
Old 02-17-2018, 08:14 AM   #5
mojoe7009's Avatar
Green Cove Springs , Florida
We installed the same chrome knobs on our window levers in our 2017 Classic. Work great with the added benefit of making the Oceanair shades go past the arms easier. The shades used to catch on the old plastic ones all the time.
Breathe In, Breathe Out, Move On
2017 Classic 30', ProPride 3P Hitch, 2016 RAM 2500 Limited CC 4x4 SRW w/ 6.7L Cummins Turbo Diesel and Retrax Pro MX Tonneau Cover
mojoe7009 is offline   Reply With Quote
Old 02-17-2018, 03:55 PM   #6
greghoro's Avatar
2013 25' Flying Cloud
Wheaton , Illinois
At one time the knobs came with threaded metal inserts to accommodate a set screw. I had a few. Unfortunately, tightening the set screw tended to pull the insert out of the knob, so generally useless. Or the knob would turn on the shaft, as there was no flat spot on the shaft.
However, I found that I could tap the hole in the plastic knob for a shallow Allen wrench set screw that I could tighten very firmly. I used a Dremel tool with grinding wheel to create a flat spot on the shaft to keep knob from turning. Been holding up for more than a year with no need for retightening.
Away from trailer, so can’t provide specifics on dimensions.
Greg
greghoro is offline   Reply With Quote
Old 02-18-2018, 11:27 PM   #7
S/O#080
Tschupp's Avatar
2006 30' Classic S/O
Tucson , Arizona
My 2006 Classic has a screw in the underside of the knob that can be adjusted.
Tschupp is offline   Reply With Quote
Window lever knobs for our 2018 Intíl Reeltimer 2016 - Current International 8 03-02-2018 07:34 PM
Where can I find the knobs for the window tilt out handle/lever? ClayDC General Interior Topics 22 06-26-2017 11:03 AM
Window latches and window lift knobs Betsy Hiker Airstream Classifieds 0 02-18-2017 02:35 PM
Hehr 614 Link Lever - Window lever WANTED Huggsterman Airstream Classifieds 0 06-14-2014 01:20 AM
Window Lever Knobs 82 34Limited General Interior Topics 3 08-31-2009 05:03 PM
