My water pressure in my 2018 30' is weak. The prssure at the spigot is so good , i put a reg on it. Removed the reg, but pressure is very low. Is there something that can be adjusted inside the trailer?
There's another regulator inside the city water fitting. Perhaps it's clogged? I think it's just like the outside one, around 45 PSI.
Check your manual for details.
BTW, it's a good idea to keep the two ends of the hose together loosely when stored. I once had a lizard crawl inside and didn't discover it until he was squished at the nozzle.
There is a big difference between pressure and volume, but lack of one is often blamed on the other. If it is pressure you are lacking then it is most likely in a faulty regulator. If volume, then there is an obstruction in the line which will also cause a very weak flow.
Sam
