Water heater support update
Yeah, they’ve been putting a couple pieces of plywood in an ‘L’ shape under the back edge of the water heater since at least 2007, which is how mine was installed. Simple and not real reliable. Mine was not an issue.
I changed out the Atwood for a PrecisionTemp tankless unit which weighs a lot less, and put a better prop under the back of it. Mine was barely screwed down at first. Needs to be done a lot better, but my original did stand up for years before it changed it out. I would have liked a well-supported shelf for the Atwood. The new tankless did ok with a simple prop on many long trips.
