Old 07-17-2017, 05:58 AM   #1
2017 25' International
Chesapeake , Virginia
The bedding is dry clean only?
We just returned from our very first trip in our 2017 International signature. Had a blast, was overall a success. Now I'm home with mountains of laundry and went to wash the comforters and noticed they are dry clean only? Crazy! Anyone was them anyway with success?
Zenjen is offline   Reply With Quote
Old 07-30-2017, 09:24 AM   #2
2017 19' International
Rosemere , Quebec
Hello, I have not washed mine yet, just moved full time, did you wash or dry cleaned and how did it go ?
Projet2907 is offline   Reply With Quote
Old 07-30-2017, 10:26 AM   #3
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Frankly the quality of factory supplied fabrics is kinda Yuck. Most of us replace the bedspreads; but you might want to use yours as a pattern to do the radiused corners correctly if you want a fitted spread.
If you're going to try washing them, make a paper pattern first in case of shrinkage. I'd use Cold water, gentle cycle to wash and partially dry on low heat and finishing on a line wrong side up.
Paula
Old 07-30-2017, 01:39 PM   #4
Rivet Slave
Rocinante's Avatar
2014 27' FB International
Green Cove Springs , Florida
We solved that problem by putting the factory-supplied bedding into a plastic bag and storing it at home in a closet, going instead for a hand-made quilt from Mom.
Rocinante is our 2014 International Signature 27FB
To Dry or Not to Dry...that is the question 4riveteers Dehumidifiers & Ozone Generators 12 11-12-2019 09:32 AM
Are "Airstream Only" Parks Really "Silver Only"? JimGolden On The Road... 28 08-22-2015 11:58 AM
Airstream Centered Jokes..Only Clean Ones Please!! RedSHED Our Community 12 10-10-2013 06:39 AM
Gaucho Cover: Wash or Dry Clean? jmpratt Upholstery, Blinds, Walls & Interior Finishes 0 05-03-2012 04:30 PM
dry clean only gowyn Upholstery, Blinds, Walls & Interior Finishes 7 07-08-2006 09:19 PM
