11-25-2019, 07:58 AM
2020 16' Bambi
Youngstown
Intermittent water leak in 2019 International 30’
Water leaks on floor along toilet supply line, or may show up coming from under refrigerator on either side. It is random. Doesn’t have to be raining. Once it is dried up, may not happen for a couple of days. Could the water supply regulator be at fault?
11-25-2019, 08:45 AM
Airstream Ambassador
Jackson Center
, Ohio
Hi Airstim,*
We're very sorry to learn about the issue you are having. Please send us a direct message with your contact information and the last 6 digits of your VIN so we can share it with our Customer Service and Technical Support team. We look forward to helping you get this resolved.
You can also reach Airstream Customer Service and Technical Support at*customer_support@airstream.com*
Thank you.*
Official account for Airstream, Inc.
Airstream Customer Service and Technical Support can be reached at 1 (877) 596-6111, option 1.
11-25-2019, 09:15 AM
2020 16' Bambi
Youngstown
Originally Posted by AirstreamInc
Hi Airstim,*
Thank you.*
Thank you.
Contact information:
Sammy Stockstill (850) 819-0746
Christine Stockstill (850) 818-2472
Last six of VIN: 545244
FYI: We use Dixie RV in Defuniak Springs, FL as a service department.
Thanks so much for your response!
11-25-2019, 09:56 AM
2018 25' Flying Cloud
Bristow
, Virginia
Water leak
I had the same thing. It appears some of the toilets tend to leak from where the pedal meets the toilet. They replaced mine under warranty. Its a slow leak, takes a few flushes before noticing a table spoon or so of water collecting around the base of toilet or area it flows to based on trainer lean.
11-25-2019, 11:06 AM
2020 16' Bambi
Youngstown
What is strange is that is coming from under refrigerator on either side of the breaker panel. Not consistent. Could you see it at base of toilet? Thanks.
11-26-2019, 10:15 AM
2016 30' Classic
Victoria
, British Columbia
Pull off the lower fridge external vent cover and ensure that the drain hose is positioned to allow water to drain outside the fridge compartment. The fact that it is sporadic, and has nothing to do with rain would indicate to me the possibility of a fridge defrost drain allowing water to enter the coach.
11-26-2019, 06:05 PM
2019 25' Flying Cloud
Lakewood
, New Mexico
We've also two intermittent water leaks. One was at the city water inlet and the other was at the water inlet connection to the toilet. Strangely, they only leaked when using the shower (high water flow). The fix was to disconnect the fittings, put a tiny amount of plumbers lubricant on the seals and reconnect. Currently, nothing is leaking, but I keep an eye on them. I notice, that on your floor plan, that the toilet backs up to your fridge. If it is the toilet connection that's leaking the water could easily flow under your fridge.
11-27-2019, 06:04 AM
2020 16' Bambi
Youngstown
Thanks.
11-27-2019, 06:05 AM
2020 16' Bambi
Youngstown
Thanks.
11-27-2019, 08:54 AM
2020 16' Bambi
Youngstown
Thanks.
Drain seems okay. Still located in original position and not blocked. I see no evidence of water running back. Appreciate the advice!
