Old 07-14-2019, 03:19 PM   #1
77domer's Avatar
Prescott , Arizona
dealer installed solar
My sun explorer display quit on my 2017 25ft international. going to replace with a victron system. Anyone know where they would have installed the charge controller?
77domer is offline   Reply With Quote
Old 07-14-2019, 03:32 PM   #2
Half a Rivet Short
Carlisle , Pennsylvania
Hi
The Sun Explorer panel does crash from time to time. The fix is normally to just unplug it and plug it back in. You can either unscrew it from the wall and unplug that end or do it at the charge controller.
The charge controller is normally by the main DC distribution block at the front of the trailer. Just where that is depends a lot on the exact floor plan you happen to have. In ours its under the center of the sofa.
Old 07-14-2019, 03:38 PM   #3
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
On mine it was forward, port side under the bed.
Larry
lsbrodsky is offline   Reply With Quote
Factory vs. Dealer Installed Options FarFetched Dollars & Cents 2 04-24-2017 03:19 PM
Is this a factory installed solar panel ? I think it's factory installed and ... JacobMerridy Electrical - Systems, Generators, Batteries & Solar 1 01-14-2017 09:23 AM
Dealer installed 2006 inverter lucca53 Batteries, Univolts, Converters & Inverters 4 06-23-2016 03:09 PM
Prodigy RF Remote Not Installed By Dealer davidahn Brakes & Brake Controllers 6 10-07-2014 10:11 PM
Wrong axles installed by dealer? akflyer Axles 5 06-10-2014 09:18 PM
