Old 06-19-2019, 06:28 AM   #1
2019 28' International
Murphy , Texas
Bathroom Door very loose
On our 2019 Int Sig RBQ the bathroom door doesn't close very tight. Meaning, it closes and latches properly, but there seems to be a lot of play at the latch when closed.. Is this normal?
Jkreis is offline   Reply With Quote
Old 06-19-2019, 06:38 AM   #2
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Old home owner's trick. If the play is caused by a too wide gap between the lock and the strike plate, remove the strike plate and cut a piece of thin cardboard (cereal box, etc.) into fit behind it, then reinstall the plate. Moves the plate about 1/16 inch closer to the lock.
Old 08-12-2019, 07:24 PM   #3
VaTravelers's Avatar
2017 28' International
I had a similar issue with my 2017 International 28 Serenity. In addition to the loose latch the gap between the door and frame got wider as you moved toward the bottom of the door frame. On our warranty visit to JC, they simply removed a screw at the bottom of the frame and moved it over 1/4 inch. Fixed the problem.
VaTravelers is offline   Reply With Quote
Old 08-13-2019, 03:47 AM   #4
2019 30' International
Pennsylvania , Pennsylvania
Get a little adhesive felt sticky, or clear rubber bumper, and stick it in the door jamb.
If you ain't havin' fun you ain't doin' it right
2017 Ford CCSB F250 XLT 6.2L Gas 4x4 Ruby
2019 International Serenity 30 Rear Twin
majorairhead is offline   Reply With Quote
Firan Ultrastar Class A RV Arched Roof Like Air Stream Very Very Nice eBay Watch Airstreams on eBay 0 03-29-2012 11:10 AM
Squarestream 5th wheel - all aluminum! very,very rare! wanderer1 All Squarestream Trailers 20 01-07-2008 08:10 AM
very old and very new horsefoot Member Introductions 4 10-02-2007 07:43 PM
How to tighten loose pocket door? tkoch General Interior Topics 1 09-04-2005 04:50 PM
Loose exterior door hinge bolts JoeGillis Doors & Locks 2 10-21-2002 11:11 AM
