Originally Posted by randydeshong
I am on maiden voyage in 2016 25 ft. International and plugged in thirty amp service last night and unit would not cool. It was in ac mode and set to 72..
It would not produce cool air. I turned off several times and kept checking settings. After an hour it finally started working.
I lean towards thermostat. When l checked inside temp on thermostat it indicated 32 degrees when it was not working.
Any ideas
Re-set the t/stat before you do anything else.
•Turn the t/stat to 'off'
•Hold the 'mode' and 'zone' buttons down at the same time
•iNiT will display in your window.
•Turn on the t/stat
try it again.
lewster
