Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > International > 2016 - Current International
Old 07-19-2019, 11:07 AM   #1
2019 30' International
Estero , Florida
2 Zone AC - flow issues
We have a 2019 30' Serenity with two ACs. When we have either one zone (doesn't matter which one) or both on, the flow at the back of the camper is really strong, you go to the front and it is almost non-existent.
Anyone else have that issue? Interested in any responses from Airstream or things that you found out.
Rich
KariRich is offline   Reply With Quote
Old 07-19-2019, 12:29 PM   #2
Overkill Specialist
GMFL's Avatar
2020 30’ Globetrotter
2014 23' International
Dadeville , Alabama
You may want to examine your duct work. I’ve head of others that have have a piece of insulation fall and block air flow.
Instagram @Airstream_Nuts_And_Bolts
DoItYourselfRV Articles
Certified Victron Installer
Old 07-19-2019, 02:13 PM   #3
Half a Rivet Short
2022 Interstate 24X
Carlisle , Pennsylvania
Hi
Also check your filters ....
Old 07-19-2019, 03:02 PM   #4
Stay Calm and Stream On
HHPJ's Avatar
2017 25' Flying Cloud
Palm Springs , California
I was getting little air flow, a piece of the insulation blew off and covered most of the filter... after doing some poking around a lot of the installation is not attached to anything, but it’s sort of shoved in there.
Stay Calm and Stream On!
HHPJ is offline   Reply With Quote
Which one is zone 1 and zone 2? Doc Foster Furnaces, Heaters, Fireplaces & Air Conditioning 9 06-23-2017 10:52 PM
Can I run the furnace in one zone and the heat pump in the other zone? Philip Jones Furnaces, Heaters, Fireplaces & Air Conditioning 2 04-15-2017 03:24 PM
Axles, brakes, hubs, tires...all out of my comfort zone chsw Axles 2 06-24-2012 12:34 AM
Leak no more - tales from the toilet zone janetb Sinks, Showers & Toilets 11 05-14-2007 03:57 PM
