Old 02-10-2017, 07:20 AM   #1
MarkJUrban's Avatar
2016 30' International
Richfield , Ohio
12V Interstate Batteries to 2 Lifeline 6V AGM
I've made some rookie mistakes during the first season with our Airstream. Roasting my interstate batteries being one of them.
Yesterday I ordered replacements. 2 Lifeline 6v GP1-4CT. Based on the battery box I believe this was the max battery amp hours I could fit without modifications.
I am trying to determine if I should also upgrade the battery charging system.
Any thoughts on this?
MarkJUrban is offline   Reply With Quote
Old 02-13-2017, 05:10 PM   #2
2017 25' International
Carlsbad , California
Mark, my wife and I recently purchased a 2017 and upgraded to two 6v deep cycle flooded batteries w 200 watts of solar (very nice for dry camping). In addition I ordered a progressive dynamics PD4655v on line. This converter is multistage and will automatically reduce the charge as the batteries reach their maximum charge. While I am not an electrician, I was able to install install it without any problems. Very straight forward.
-Overthehills
OvertheHills is offline   Reply With Quote
Old 02-23-2017, 11:51 AM   #3
HD Pilot's Avatar
2017 23' International
Decatur , Texas
I have not done the battery upgrade yet but did install the PD4655. If you do a "Search" here, there are some good install Threads and also there are 1 or 2 good YouTube videos too.
HD Pilot is offline   Reply With Quote
Old 02-24-2017, 02:50 PM   #4
DoublTrouble's Avatar
Over, that is awesome advice!
DoublTrouble is offline   Reply With Quote
Old 02-25-2017, 11:27 PM   #5
2016 19' Flying Cloud
Portland , Oregon
I posted a couple of threads in the electrical and battery forums on both these topics. Pictures of PD4655 install and dual 6v upgrade.
Snowy is offline   Reply With Quote
Old 02-28-2017, 07:36 AM   #6
MarkJUrban's Avatar
Richfield , Ohio
Thanks for the info. You have me in the right direction. I posed the same question to bestconverter.com. Below is the response:
Hi Mark,
I just need to know if you have 30 or 50 amp service. If its 30, they the 8355 is what you have and I recommend the Progressive Dynamics 4655V with remote. Here is a link.
PD4655V
If you have 50 amp service (2 air conditioners) they you will have to use a deck mount like the Boondocker 60 hard wire since there is no upgrade kit. Its not difficult and you still end up with a 4 stage smart charger. Here is a link to that procedure.
Parallax 8355 to boondocker
http://www.bestconverter.com/Paralla...e_ep_25-1.html
Randy
BestConverter
I let randy know that I have the 50 amp service with two air conditioners. I also inquired about the Iota brand. I will keep this thread posted.
Old 03-01-2017, 07:01 PM   #7
HD Pilot's Avatar
Decatur , Texas
Hey Mark, it appears that the Lifeline 6V batteries do not have the round posts that the main + and - cables from the Airstream connect to on the Interstates...maybe Randy gave you some advice? Wondering if you have to change out the wire connectors or something?
Old 03-01-2017, 07:11 PM   #8
Portland , Oregon
Just cut off the round post connectors and crimp on lug connectors.
Old 03-01-2017, 07:29 PM   #9
Naples , Florida
Agreed!
I NEVER re-use the automotive type of connector as they can never be tightened sufficiently for long term deep cycle use. The only connectors I use are either solid copper big ends or marine grade tinned copper lugs.
Proper crimping is essential for these to work correctly, but they are well worth the effort.
Old 03-01-2017, 11:31 PM   #10
Portland , Oregon
If you are not comfortable in cutting off the round pole connectors you can buy battery posts off Amazon etc. Just wanted to give you another option.
Old 03-02-2017, 01:55 PM   #11
HD Pilot's Avatar
Decatur , Texas
Do you crimp and solder or just crimp? Thanks.
Old 03-02-2017, 03:58 PM   #12
Portland , Oregon
Personally I just crimp.
Old 03-02-2017, 04:48 PM   #13
DaveP's Avatar
2004 28' Classic
Monument , Colorado
Crimp the lugs on then use adhesive lined heat shrink tubing to protect the crimp from the elements and to strain-relief the crimp joint. Here is a link to the tubing on Amazon: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
BTW, the Lifeline batteries will arrive with the proper bolts and washers to connect the lug terminals to the batteries.
DaveP
2004 Airstream Classic 28 "Willard"
2023 Ram 3500 4x4
DaveP is offline   Reply With Quote
Old 03-06-2017, 08:33 AM   #14
HD Pilot's Avatar
Decatur , Texas
Good info!
Where are you guys getting the 2/0 series battery cable? Looks like there is an eBay seller or 2 that will make one to any length you want.
Old 03-06-2017, 08:42 AM   #15
2013 20' Flying Cloud
Between Here and There and Nowhere , what have you got?
I used this cable from Amazon. Top notch!
openroad118 is offline   Reply With Quote
Old 03-06-2017, 08:46 AM   #16
DaveP's Avatar
2004 28' Classic
Monument , Colorado
I got my cable from Amazon https://www.amazon.com/Gauge-Premium...+welding+cable.
I happen to know the guys at EWCS and they make good products. The (welding) cable is very flexible and easy to use. I used Ancor galvanized lugs (also from Amazon).
BTW, depending on the length of the cable runs, you may need to go to 3/0 or 4/0 cable.
DaveP
2023 Ram 3500 4x4
Old 03-06-2017, 08:50 AM   #17
DaveP's Avatar
2004 28' Classic
Monument , Colorado
Well, I guess openroad and I are in agreement on a good cable for you to use!
DaveP
2023 Ram 3500 4x4
Old 03-06-2017, 08:57 AM   #18
DaveP's Avatar
2004 28' Classic
Monument , Colorado
Looks like Hammer Marine Supply in Decatur could make them for you. https://hammermarine.com/product-category/wiring-looms/
DaveP
2023 Ram 3500 4x4
Old 03-06-2017, 10:44 AM   #19
hshovic's Avatar
2007 25' Safari FB SE
Bozeman , Montana
Images: 20
Battery upgrade
Take a look at this old thread. I have since put 90,000 miles on the 2008 AS, and just replaced my AGM's last year.
At 20 deg I still get two nights of heat with no hookups.
http://www.airforums.com/forums/f449...tml#post514373
Hank
WBCCI 1489 AIR 20708
2015 Chevy 3/4 ton 4 x 4 gas; 2007 Safari FB SE
"Its better to light just one candle than to curse the darkness,
Unless you're blinded by the light..."
hshovic is offline   Reply With Quote
Old 03-06-2017, 12:32 PM   #20
MarkJUrban's Avatar
Richfield , Ohio
Hey guys, thanks for the info.
I didn't even think about the battery cables. Batteries are still in the house...
Below is he response from bestconverter.com when I asked about the iota brand.
"Hi Mark,
The Boondocker is a 4 stage smart charger and much better charge profile than the Parallax single stage. The Iota is a different brand similar to the Boondocker but I would use the Boondocker. Great charge profile, less money and better warranty. Thanks!
Randy
BestConverter"
I will give the boondocker a try unless someone can think of a reason not to.
Mark
12v
Why Interstate Lifeline AGM batteries die Boxster1971 Sprinter and B-van Forum 29 06-02-2016 08:04 AM
How I changed my Lifeline AGM batteries SilverGate Batteries, Univolts, Converters & Inverters 7 03-14-2016 06:24 PM
surprise - have Lifeline AGM in my 2010 25fb Anders79 Batteries, Univolts, Converters & Inverters 6 08-18-2015 10:40 AM
New Lifeline AGM 31 group depleted batteries F450Harley Electrical - Systems, Generators, Batteries & Solar 6 11-06-2013 07:02 PM
AGM Battery: Cabela's or Lifeline? Sheridan Batteries, Univolts, Converters & Inverters 11 03-06-2009 10:30 AM
