Old 09-06-2017, 04:53 AM   #43
2017 22' Sport
Hermitage , Tennessee
TinkersToy, I have a 2017 22FB and am interested in the details of your bumper upgrade. I am a do-it-yourself-er, but I don't weld. Did you install the bumper or have it done? Thanks!
Mike Lonas
KM4MSL
2017 Sport 22FB
2015 Ford Explorer 3.5L EcoBoost
mlonas is offline   Reply With Quote
Old 09-06-2017, 07:57 AM   #44
kscherzi's Avatar
2013 27' FB International
El Dorado Hills , California
Images: 24
The other thing I happened to notice when following my friends Airstream is the turn signal and brake bulbs are the same. In other words when turning and stopping at the same time all the person behind you sees are brake lights. So putting on the flashers when backing won't work if you use the brakes at all.
kscherzi is offline   Reply With Quote
Old 09-06-2017, 12:00 PM   #45
richw46's Avatar
Lexington , Kentucky
American cars used to be set up this way. It was before they had 4-way flashers. If you were turning, the turn signal light was the brake light. The bulb on one side would flash while the other side stayed bright. When 4-way flashers came along, American cars would flash the brake lights, unless you stepped on the brake, then they just stayed bright.
Eventually, American cars adopted the European style of separate bulbs for the turn signals. Then, if you had the regular trailer lights you had to get an adapter for your car to send the turn signal voltage to the brake light bulb on the trailer, and the car and trailer bulbs blinked 180 degrees out of sync.
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE
richw46 is offline   Reply With Quote
Old 09-07-2017, 07:19 AM   #46
2015 22' FB Sport
Wethersfield , Connecticut
With the understanding that the bumper was designed to hold the backup lights and camera and not for protection, I used 3 aluminum splines from my old tonneau, some aluminum angles and L bars, and SS carriage bolts I assembled the bumper, attached the lights and camera and bolted to the trailer frame. I bought the lights on Amazon (Blazer B669BU Back-Up Lamp Chrome Bezel) photo
ID:	294266   Click image for larger version
TinkersToy is offline   Reply With Quote
Old 09-11-2017, 04:10 PM   #47
2017 22' Sport
Nice job!
Mike Lonas
KM4MSL
2017 Sport 22FB
Old 09-14-2017, 08:46 AM   #48
Vantair
Vantair's Avatar
2005 25' International CCD
Westlake Village , California
LED Backup, Work and Scare w wireless trigger
Originally Posted by Vantair View Post
Totally agree with OP "why missing backup lights". Regardless of a missing in this case a lack Gov rule.....
No gov regulations mandate a dual/triple holding tanks, toilet, heater, rain sending fans, stereo or sub. But absolutely must agree backup lights should make equal sense as running and brake lights.
All the rational why we wired and added our own.
Posted this year ago but for fresh viewers decided to not put non standard lights or holes in the shell / bumper. Crafted simple aluminum backing L bracket behind license and very bright water proof LED Bar. Brought wiring from nearby inside hatch courtesy light adding flush manual switch also a long range wirless Fob receiver. Allows on / off for backing up, breaking night camp lighting, emergency road hazard lighting and scare light triggers while sleeping. All without needing truck attached or being in "reverse".
Concealed, Very bright and more useful than just reverse lighting.
ID:	294811   Click image for larger version
Vantair is offline   Reply With Quote
Old 09-14-2017, 09:33 AM   #49
2007 27' International CCD FB
San Diego , California
So does the non-classics have the reverse wiring from the pigtail into the junction box?
Playing on Vantairs idea, it would be easy to mount to vertical light elements alongside the license plate, which most people would interpret as backup lights rather than general lighting.
2007 27FB Ocean Breeze "See Turtle"
2009 Lexus LX570
pteck is offline   Reply With Quote
Old 09-14-2017, 02:47 PM   #50
CRH
1995 25' Excella
xxxxx , xxxxxx
Originally Posted by m.hony View Post
The Excellas and Classics have always had backup/reverse lights.
And I owned my trailer over 3 years before I noticed them....
CRH is offline   Reply With Quote
Old 09-14-2017, 02:54 PM   #51
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
Center pin
AtomicNo13 is online now   Reply With Quote
Old 09-14-2017, 02:55 PM   #52
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Have them as standard on my excella. Use them every time I back up in the dark!
Old 09-14-2017, 03:50 PM   #53
Glenritas's Avatar
1969 25' Tradewind
Shasta Lake , California
Since I posted on this thread earlier , I've been looking at other newer trailers and they also do not have back up lights.
So the mystery is solved . They are not required by law on trailers anymore as Protaginost sited the FMVSS 108 .
They are optional .
Glen & Jane 1969 all electric Airstream 25' TradeWind
2014 Toyota Tundra
1998 Chevy Tahoe
2001 Casita 13' Patriot Deluxe
My Build Thread https://www.airforums.com/forums/f11...ml#post1997059
Glenritas is offline   Reply With Quote
Backup Camera, it seems so simple, why don't they...? RLWardd Electrical - Systems, Generators, Batteries & Solar 37 07-25-2017 04:12 PM
which wire is the backup wire- rearexterior backup, stop turn light waninae39 Tow Vehicles 38 07-03-2017 06:09 AM
Why we don't have mice... aircooled4 Off Topic Forum 14 08-13-2010 09:47 AM
Battery check--why don't I ever have to add battery water? Kistler Batteries, Univolts, Converters & Inverters 8 05-17-2004 09:03 PM
Why, Why, Why aviontt On The Road... 22 11-20-2003 07:41 PM
