Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Oddities
Old 12-07-2017, 07:27 PM   #1
RUMSHIP's Avatar
1988 32' Excella
Bonita , California
Images: 16
Flag poles
I’m looking for 2 flag poles that were made in Ohio. They look like may have been made from medical tubing. Made in 3 sections. The business is not making them anymore. Any help would be appreciated.
Happiness only real when shared.
Christopher Johnson McCandless
2/12/68 - 8/18/92
RUMSHIP is offline   Reply With Quote
Old 12-07-2017, 07:58 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Most seem to use adjustable paint poles.
MICHAEL
Old 12-07-2017, 08:21 PM   #3
DaveMc's Avatar
2005 30' Safari
Montgomery , Texas
Though I don’t have any, I’ve read that swimming pool brush/net poles work, too. They make those in 2 and 3 segment varieties.
DaveMc is offline   Reply With Quote
Old 12-13-2017, 04:10 PM   #4
PKI
PKI's Avatar
Walnut Creek , California
Originally Posted by RUMSHIP View Post
-- snip -- may have been made from medical tubing. -- snip --.
Found your post to be interesting in that my definition of medical tubing is the flexible stuff used to launch steel balls with a wrist rocket. Medical tubing could be constructed from Stainless Steel, Carbon fiber, or about any plastic that is structually sound and can be sterilized. So, exactly what material are you trying to find? Pat
Old 12-14-2017, 07:25 PM   #5
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
We have 3 of these poles.. I think.. They are aluminum 3 decreasing radius tubes with 'fluted' exterior. This helps them telescope in the 3 sections. There is a 'spring pin' latch to hold in place, that pops into holes as you slide the pipes, setting a length.
Each section has a hole in a chair stool leg cushion which protects the end edges of the larger sections... less likely to pinch your fingers when collapsing the pipes.
There is also a lower flag catch which keeps tension on the flag so that it remains taught and flies properly.
I can't post pics here...
Peace and Blessings..
Channing
WBCCI# 30676
3 Aluminum telescoping flag poles, esp for Airstreams AndL Airstream Classifieds 0 05-21-2014 03:37 PM
Flag Poles for robandzoe holder rochar3 Our Community 4 07-24-2011 10:40 PM
Flag Poles gaylejoe Off Topic Forum 16 06-15-2010 08:49 PM
Flag poles and holder for tongue jack NOAZRK2690 Off Topic Forum 32 11-13-2009 07:36 PM
