Old 01-19-2009, 06:51 PM   #1
1968 22' Safari
port st lucie , Florida
VIN Search via WBBCI?????
We are having trouble locating the VIN on our "new" 1966 International Safari. The plate next to the door is missing, and we are unable to locate any numbers on the A frame. We were wondering if it would be possible to locate the VIN by researching the WBBCI number. The number on this trailer is 12883.
Any help would be very much appreciated.
Thank you,
David & Janet
captmorgan is offline   Reply With Quote
Old 01-19-2009, 06:54 PM   #2
goransons's Avatar
1963 22' Safari
1955 26' Cruiser Overlander
Yakima Valley , Washington
Send a message via MSN to goransons
Have you tried paint stripper on the tongue to see if under the many coats of paint the serial number is there? Sorry I'm no help on the WBCCI angle but someone might have info.
Scott & Megan
VAC LIBRARIAN
Restoring Wally Byam's 1955 26' European Caravan Trailer!
WBCCI 8671
1963 Safari from the 1963-64 Around the World Caravan
goransons is offline   Reply With Quote
Old 01-19-2009, 07:23 PM   #3
Southwestern , Ohio
Thank you,
David & Janet
This will be a toughie since the WBCCI number pertains to the owner rather than the trailer and it's likely that the trailer has changed hands, possibly several times, in its lifetime. Streamer23 on this list has a pretty good file of member directories. Maybe he can tell you who the previous owners were, and one of them might have a record of the VIN number.
It is true that WBCCI asks for the serial number as evidence of Airstream ownership on their membership application, but I don't know if they keep that information once a member is signed up.
Both of our vintage Airstreams have a short number (4 or 5 digits) beaded on the inside of the "A" frame with an arc welder but it doesn't bear any obvious relationship with the trailer serial number. (I have always wondered what those numbers meant.)
I am sort of assuming the previous owner had a title--what does it give for a VIN number?
Good luck,
Nuvi
Nuvite-F is offline   Reply With Quote
Old 01-19-2009, 07:29 PM   #4
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
That number may have changed hands several times over the years. In many of the older trailers you can sometimes find the last 3 hand written on the bottom of draws and other removable items. It most likely helped the plant get the right stuff in the right trailer.
Richard
Old 01-19-2009, 08:49 PM   #5
1953 17' Clipper
1963 28' Ambassador
Sparta , Wisconsin
numbers
This might seem strange but on both the Airstreams I have restored the serial numbers were writen on the insides of the cabinets and on the boards for the beds. Seems this was there way of keeping things together.
1953Clipper is offline   Reply With Quote
Old 01-19-2009, 09:23 PM   #6
Thank you,
David & Janet
Your best bet, is to remove the paint on the top side of the A-frame.
Old 01-20-2009, 08:11 PM   #7
1968 22' Safari
Thanks to all for your suggestions - we'll try to remove the paint on the A frame and see what lurks beneath???
Old 01-21-2009, 04:59 AM   #8
streamer23's Avatar
NOVA SCOTIA , CANADA
Images: 18
Wbcci#12883
I have sent you the WBCCI info I have found on the number.Good luck in your search.
Mike
AIR #7916
Ex WBCCI #32083
streamer23 is offline   Reply With Quote
Old 02-05-2009, 03:57 PM   #9
1976 31' Sovereign
florissant , Missouri
did not get message
chuckstlou is offline   Reply With Quote
'69 Tradewind VIN search Eliminator46 1959-69 Tradewind 9 10-16-2008 05:14 AM
Nc wbbci jpeterman WBCCI Forum 3 10-02-2008 08:46 PM
WBBCI Ohio Unit Window Decal from the 60's PeeWee WBCCI Forum 3 09-22-2007 07:50 PM
