Old 05-11-2018, 09:13 PM   #1
2007 25' Safari FB SE
Bellingham , Washington
Zamp solar 200 watt portable solar charging kit
Title: Add New - Airstream Trailer Classifieds - Airstream Trailers For Sale
I just posted a new ad on Airstream Classifieds.
Never used. New upgraded model. Zamp Solar has done a fantastic job with the new design. They've made changes to the legs, solar charge controller, wiring harness and have added a new solar charge controller bracket called their EZ-View Bracket. Comes in its own case with handle
$800 Firm. Leave name and email. Local, meet in Mount Vernon. If ad is up still available.
200 Watt Total Power (2 Monocrystalline Panels). Made with tempered glass and sealed to the frame making it a waterproof/weatherproof panel.
11.43 Amps of Charging Power
15 Amp 5-State PWM (pulse width modulation) Waterproof/Weatherproof Digital Deluxe Solar Charge Controller - with LCD Screen Output -
Strong Aluminum Frame with Aluminum, Adjustable Support Legs Attached
Carrying Handle Attached to Aluminum Frame with Plated Steel Fasteners and Hinges
Carrying Case made of ballistic nylon
Zamp Solar Plug Equipped with Solar Plug Ready Battery Terminal Clamps
Dimensions Closed - 27" x 40" x 3"
Dimensions Open - 54" x 40" x 1.5"
You can contact us by filling in the form on the right hand column of the ad listing:
http://www.airstreamclassifieds.com/...-charging-kit/
Cascadian is offline   Reply With Quote
Zamp 160 watt portable solar kit (suitcase) dasams Airstream Classifieds 0 09-01-2017 12:28 PM
Zamp 200 Watt Panel and factory 10A Fuse dasams Generators & Solar Power 2 10-20-2016 12:12 AM
Zamp 160 watt portable solar dznf0g Generators & Solar Power 20 03-02-2016 07:10 PM
Zamp Solar-80w portable charging kit-questions EmoryRiver Generators & Solar Power 5 05-14-2013 03:25 PM
