Title: Add New - Airstream Trailer Classifieds - Airstream Trailers For Sale
I just posted a new ad on Airstream Classifieds.
YAMAHA EF2400IS 2400 WATT INVERTER GENERATOR
HARDLY USED FOR MY R’VING .
JUST GOT SERVICED AT YAMAHA DEALER.
Tired of running this unit every month and also it is too heavy for loading and unloading.
DESCRIPTION
The 2400 Watt Yamaha EF2400iS weighs 75 pounds and has a dual-handle design, making it easily portable. With an aluminum die-cast frame, the EF2400iS features Smart Throttle which allows greater fuel efficiency and noise reduction. It will run up to 8 hours at ¼ rated load on a tank of gas. With features such as Pulse Width Modulation, at-a-glance fuel gauge, the EF2400iS is a great choice for a medium-sized portable inverter!
FEATURES:
Yamaha generators have the longest emission engine durability ratings issued by the Environmental Protection Agency and the California Air Resources Board.
Gasoline petcock lets you shut off the gas to run the carb dry for storage and helps prevent stale gas problems.
Fuel gauge allows fuel level to be seen at-a-glance.
The EF2400iSHC uses Pulse Width Modulation (PWM) to produce high-quality electricity comparable to the power supplied by public utilities. Use this generator with confidence as a power source for microcomputer-controlled appliances and other devices with built-in computer functions.
Yamaha’s Smart Throttle feature automatically adjusts engine speed to match the load. The result is quiet running, maximum fuel efficiency, and a run time of 8.6 hours at 1/4-capacity load
High Current output - Increased motor starting capability and improved air conditioner starting. This High Current model starts most high efficiency 13,500 btu AC
Pulse Width Modulation - Provides power that is as clean, or cleaner than commercial power.
Smart Throttle feature - Adjusts the engine speed to precisely match the load.
OHV engine - Improved efficiency, increased reliability, quieter operation.
Compact and lightweight - Easy portability.
Versatile power in the silent, 2000-watt class - Will run most 13,500 btu RV air conditioners, microwave/convection ovens, or even the biggest hair blow dryer.
Engine speed at full load (2400 watts) is only 3400 rpm - Quiet operation.
Cast iron cylinder liner - Provides long engine life and consistent performance during continuous use.
Removable back access panel - Easy servicing.
Fuel gauge - See fuel level at-a-glance.
Aluminum die cast frame - Strong yet lightweight.
Gasoline petcock lets you shut off the gas to run the carb dry for storage - Prevents stale gas problems.
12 volt DC cable is included as standard equipment - Charge RV, ATV, motorcycle, marine, and automotive batteries.
EPA & CARB Emission Engine Durability Rating - Yamaha generators have the longest emission engine durability ratings issued by the Environmental Protection Agency and the California Air Resources Board.
50 state legal - Meets emission regulations, including CARB.
You can contact us by filling in the form on the right hand column of the ad listing:
http://www.airstreamclassifieds.com/...ator-ef2400is/
