Old 09-30-2014, 09:32 PM   #1
duckdave's Avatar
1971 31' Sovereign
2006 22' Parkway
Little Rock , Arkansas
Wood Grain Door Panels for Dometic RM100
Title:
I just posted a new ad on Airstream Classifieds.
These are the original door panels from the original Dometic RM100 refrigerator in my 1979 31' AS Sovereign. I had to replace the fridge and could not use these panels in the new one. They are in very good shape. They are vinyl wood grain (like the rest of the cabinets) on a thin sheet (about 1/8") of 3-ply plywood. Included are the plastic trim pieces and screws that hold these in place.
Panel dimensions:
Freezer panel 13 1/8 x 23 1/4
Refrigerator panel 23 to 23 3/16 x 35 Panel slightly tapers, but installed on my fridge you could not detect it; all edges were covered.
To install you bend the panel slightly, left and right and insert the sides into the door trip. Once fully inserted into the side tracks, you slide the panel down (refrigerator compartment) or up (freezer compartment) and insert the plastic trim secured with two small screws in the corners, to hold them in place.
Please note: these panels are from a Dometic RM100 refrigerator. Panel dimensions are given above. I suppose it would be possible to cut them down to fit other smaller refrigerator units.
You can contact us by filling in the form on the right hand column of the ad listing:
http://www.airstreamclassifieds.com/...dometic-rm100/
duckdave is offline   Reply With Quote
Need help on installing Dometic RM100 fridge door seals carol4266 Refrigerators 3 03-24-2017 10:21 AM
Swollen Door Dometic RM100 NewbieAndy Refrigerators 3 07-03-2012 12:53 PM
grain on 89 skin Perry Cleaning, Stripping & Polishing 1 02-17-2008 02:49 PM
Painting info for 70's wood grain panels Road Ruler General Interior Topics 17 02-03-2007 07:48 AM
Original wood grain laminate (74) AV8 Upholstery, Blinds, Walls & Interior Finishes 1 01-19-2004 08:33 AM
