Old 07-23-2016, 04:57 PM   #1
2016 30' Classic
Portland , Oregon
Send a message via Skype™ to synapticon
WFCO 1000 Watt Pure Sine Wave Inverter
Title: Add New - Airstream Trailer Classifieds - Airstream Trailers For Sale
I just posted a new ad on Airstream Classifieds.
I upgraded the electrical system in my new 2016 Classic to Li batteries and solar array. Inverter and batteries are essentially in new condition (1 month old).
WFCO 1000 Watt power inverters are engineered for outstanding performance. They provide high-efficiency power at full-load conditions with safeguards that include; overload protection, over-temperature protection, and short-circuit protection. The cooling fan enhances efficiency as its operation is controlled by the amount of load incurred by the inverter.
When connected to either shore power or a generator, the WFCO inverter provides direct AC pass through. FCC Class B compliance, which means that the converters are designed not to cause interference with televisions, radios or other signals. The upgraded WF-5110HP model simplifies and provides certainty in product testing and on the production line for RV manufacturers. The WF-5110HP features a plug-and-play design that allows it to be simply plugged into an AC outlet to connect directly to the RV’s AC system. It will convert 12 VDC to 110 VAC, and has a remote control system and built-in circuit protection on the AC side.
1000 Watt continuous output for electronic appliances
Pure sine wave output to operate higher end electronic equipment
Built in 2 milliseconds transfer time. This allows the transfer from utility power to invert power to be interruption free, protecting sensitive equipment.
LCD display with all operation status
UL 458 approved
Battery over and under voltage protection
Over temperature protection
Over load protection
Short circuit protection
Reverse polarity protection
AC output fuse (15 amp/600VAC) for over current protection
Dimensions: 13.25" (L) 8.75" (W) 4" (H)
Weight: 12 lbs
You can contact us by filling in the form on the right hand column of the ad listing:
synapticon is offline   Reply With Quote
6 months with the AIMS 2000 Watt Pure Sine Inverter Charger trekerboy Batteries, Univolts, Converters & Inverters 9 07-10-2017 07:17 AM
Magnum MMS1012 1000W Pure sine Wave Inverter w/50 Amp Charger & Remote exallen Airstream Classifieds 0 06-05-2016 03:25 PM
Modification to reduce fan noise for the WFCO 1000 W Inverter alano 2011 - 2015 Classic (all lengths) 8 05-08-2015 01:26 PM
Sterling Power Pro Combi S Pure Sine Wave Inverter Charger Don Diego Batteries, Univolts, Converters & Inverters 8 12-27-2013 06:16 AM
Anyone know about pure sine wave converters? mikeandnora Electronics & Connectivity 4 06-04-2012 08:02 PM
