Old 10-14-2016, 04:50 PM   #1
2015 16' Sport
1995 21' Sovereign
Portland , Oregon
Viair 400P-RV automatic portable compressor kit
Title: Add New - Airstream Trailer Classifieds - Airstream Trailers For Sale
I just posted a new ad on Airstream Classifieds.
Gently used Viar 400P-RV portable compressor kit with inflation gun and gauge, two air hoses with quick connect fittings, and attachments for sale.
This compressor is capable of pressurizing up to 150 psi, and provides 2.3 CFM in free flow (0 psi). This makes it especially handy for winterizing water lines (http://www.thervgeeks.com/winter-rvi...v-water-lines/) and inflating tires wherever you are (http://www.thervgeeks.com/product-re...res-made-easy/). It is kind on the ears and automatically shuts off when it reaches pressure. The compressor has a vibration-resistant base, air filters, and a handy carrying case.
Viair is a well-known brand and this is a well-made compressor. We used it for airing up tires before leaving a campground and winterizing our camping trailer. It was also a relief to know that we had it if we ran in to tire trouble on the road, far from service stations.
We sold the trailer and don’t need it anymore.
From the manufacturer: “400P-RV Automatic offers automatic shut-off in a larger portable compressor kit that can inflate 35-inch tires from 0 to 30 PSI in less than 5 minutes. While the unit is intended for RV use, it can be used for virtually any tire since it comes with more accessories for more varied inflating situations than any other portable compressor kit on the market today.
Portable compressors with automatic shutoff come into play when moving from tire to tire, and when checking tire pressure in the middle of a tire fill. A typical portable compressor must be turned off between tire fills, and anytime you want to check tire pressure. If you aren’t near the compressor, this can turn into running laps back and forth to the portable compressor to turn the unit on and off. Automatic portables do not work in this fashion and will save you time & effort to get tires inflated quickly.”
Features:
- Automatic Shut-Off Function
- Primary & Extension Air Hoses
- Vibration-Resistant Diamond-Plate Sand Tray
- Heat Shielded Quick Connect Coupling
- Tire Inflation Gun with 130 PSI Inline Gauge
- Heavy Duty Dual Battery Clamps with Inline Fuse
- 45-Degree Extended Reach Chuck (For Dual Rear Wheels)
- 90-Degree Twist-On Chuck
- Heavy Duty Deluxe Carry Bag
- 3 pc. Inflation Tips Kit
Specifications
- 12-Volt
- Permanent Magnetic Motor
- Duty Cycle: 33% @ 100 PSI
- Max. Working Pressure: 150 PSI
- Max. Amp Draw: 30 Amps
- Dimensions: 10.9"L x 5.8"W x 7.5"H
- Net Weight: 10.75 lbs.
- Power Cord Length: 8 ft.
- Primary Air Hose Length: 30 ft.
- Extension Air Hose Length: 30 ft.
$150 ($275 new)
You can contact us by filling in the form on the right hand column of the ad listing:
http://www.airstreamclassifieds.com/...ompressor-kit/
goofus delux is offline   Reply With Quote
VIAIR Questions AIRHEDS Winterizing, Storage, Carports & Covers 3 11-14-2016 05:41 AM
Viair 88p 12v air compressor. Caffeinated Tires 5 07-14-2016 09:06 AM
RELAX 12v AUTOMATIC AWNING RETROFIT KIT by Zip Dee for Main Awning LaBigDogs Awnings 12 07-30-2013 02:02 PM
Portable Compressor Recommendation wlanford Tires 4 07-14-2011 08:29 PM
Portable air compressor JBinKC Tires 16 05-30-2010 09:40 AM
