Go Back   Airstream Forums > Airstream Community Forums > Airstream Classifieds
Old 09-04-2014, 07:29 AM   #1
1983 31' Excella
Yulee , Florida
Tambour
Title:
I just posted a new ad on Airstream Classifieds.
I have some cut-offs from full sheets of Tambour left over from my projects. Incidentally, because the material is so thin and can "tear" rather than cut one should use specialized equipment. I used to make reproduction antique pool tables so I have veneer cutting equipment and experience. So, if anyone needs any let me have the size you want and I'll see if I can make it. If you wish you can send me the handle and I'll fit it for you.
When measuring Tambour it's important to state the length of the slat (SL). In the instance of the Tambour door under the sink in my photo the overall measurement from top to bottom is 18-78ths" and 45-1/2" long. It could be described as: SL18.875 x 45.5" or 18-7/8ths x 45-1/2"
You can contact us by filling in the form on the right hand column of the ad listing:
http://www.airstreamclassifieds.com/ads/tambour-3/
AFUser is offline   Reply With Quote
Tambour..... Chuck Cabinets, Counter Tops & Furnishings 9 02-18-2016 09:56 PM
Replacing Tambour [Credenza] niftypkg Cabinets, Counter Tops & Furnishings 5 01-16-2007 12:36 PM
Tambour Door Resources InsideOut Link Archive 4 09-23-2002 03:12 AM
Cabinet Door Retrofit to Tambour Doors ARGOSY79 Cabinets, Counter Tops & Furnishings 5 08-28-2002 08:34 AM
Must be sick of me by NOW - Tambour Door repair niftypkg Cabinets, Counter Tops & Furnishings 3 07-05-2002 11:11 AM
