Old 01-26-2015, 02:37 PM   #1
Snaken49's Avatar
2010 28' Flying Cloud
Fort Worth , Texas
Slightly used Baraldi Range Hood
Title: Add New - Airstream Trailer Classifieds - Airstream Trailers For Sale
I just posted a new ad on Airstream Classifieds.
SWING PRO:
Sophistication that is characterized by aerodynamics and elegant lines. When inserted into the cabinet, the discrete low profile versions reveal less than 2" of height while concealing Baraldi's fast and powerful Jet-flo ventilation technology.
Residential style, multi-layer aluminum filters that utilize the entire perimeter of the range hood are combined with a powerful motor and centrifugal fan wheel to more effectively extract heat, grease, and smoke from the cooking area. Centrifugal fans can generate higher pressure at lower sound levels when compared to axial fan blades commonly used in recreational vehicle vents.
Fast and Powerful Jet-flo Ventilation:
194 CFM completely exhausts an average 25' trailer in under 7 min
2,150 RPM creating 4.6 lb/sq ft.
20 watts 12VDC
Whisper Performance: 56db (normal voice conversation at 3-5ft = 60db)
Halogen Lights: Two at 10 watts (140 lumens each)
"Easy-Clean" large, residential-style, removable grease filter
Unit is slighty used and has new switch and filter screen. See link for pictures and description.
http://www.airstreamsupply.com/baral...-12v-rv-106915
You can contact us by filling in the form on the right hand column of the ad listing:
http://www.airstreamclassifieds.com/...di-range-hood/
Snaken49 is offline   Reply With Quote
Baraldi Range hoods, The Stainless steel Range hood found in 2009 Airstreams AeryCorp Commercial Listings 18 05-10-2016 01:41 PM
LED Conversion: Baraldi Range Hood Lights TinTin Lights - Interior & Exterior 5 07-13-2014 02:38 PM
Needed: One slightly used land yacht engine Johnsito General Repair Forum 7 09-15-2013 07:32 PM
Baraldi Range Hoods dznf0g General Appliance Topics 1 04-25-2013 05:13 PM
Your opinion needed, New 2008 or Slightly Used 2006 ericwarren Our Community 19 08-30-2008 04:21 PM
