Old 10-22-2014, 07:00 PM   #1
tphan's Avatar
1972 27' Overlander
Longmont , Colorado
Original front vent fan assembly from 1972
Title: Add New - Airstream Trailer Classifieds - Airstream Trailers For Sale
I just posted a new ad on Airstream Classifieds.
This is the original front sky-light fan assembly from a 1972 Overlander. consists of fan motor, plastic fan blade, 2 metal mounting straps, and sky-light-crank-activated switch. comes with all necessary nuts and bolts. The fan motor works, but it has gotten a little "gummed up" from lack of use, and spins slowly and grudgingly. I think that if you just took it apart and cleaned the old, sticky grease/dirt out of it, it would likely work just fine. It used to work just fine....
Just pay for shipping costs, plus $5. it weighs 3 lbs. It's coming from Longmont, Colorado 80503.
You can contact us by filling in the form on the right hand column of the ad listing:
http://www.airstreamclassifieds.com/...bly-from-1972/
tphan is offline   Reply With Quote
Original HEHR Roof Vent Assembly steveirving Airstream Classifieds 0 06-25-2014 05:08 PM
Fan-tastic Vent 3000BT Fan 110 Volt, 3 Speed, Smoke Dome top, Built in Thermostat? stc cigar Airstream Classifieds 0 02-19-2014 08:45 AM
Front vent fan not shut off cwf Roof Vents, Skylights & Fans 5 04-11-2013 06:37 AM
Fan in front light vent RBrown-72 Electrical - Systems, Generators, Batteries & Solar 1 08-06-2012 09:39 PM
Fan-Tastic Vent Fan roadliner54 Our Community 2 07-11-2011 11:14 AM
