Old 08-19-2019, 08:36 AM   #1
Chicago , Illinois
NEW! Electric Trailer Brake Kit - Self-Adjusting - 12" - Left and Right Hand Assemblies - 5.2K to 7K
Title:
I just posted a new ad on Airstream Classifieds.
*Local pick-up only.
Self-adjusting driver's-side and passenger's-side brakes are 12" x 2". Brake pads are made of durable friction material for improved braking and longevity. E-coated backing plates resist rust. Fit 14.5" to 16.5" wheels.
Features:
Electric brakes are easier to install and offer more user control than hydraulic brakes
Require only an electric brake controller (sold separately) - no actuator or hydraulic lines necessary
Automotive-grade friction material is molded to brake shoes
Pads are fully bonded - not riveted - to shoes for long life and more braking torque
Less chance of cracking and crumbling that can lead to mechanical lockup, thanks to tapered edge and circular grinding
Self-adjusting brakes do not require periodic manual adjustment like standard brakes
Fine-tooth brake adjustment gears allow for a more precise setting
E-coated backing plates resist wear and corrosion
Adjuster plugs (included) cover access holes to keep dirt and grime out of the assemblies and off of the shoes
Left-hand (driver's-side) brake assembly and right-hand (passenger's-side) brake assembly included
Mounting bolts and hardware (BRKH12) sold separately
QAI and CSA certified
Specs:
Application: most standard hub-and-drum assemblies, including Dexter, Lippert (LCI), and AL-KO
Dimensions: 12" diameter x 2" wide
Mounting flange bolt pattern: 5 bolt
Wheel size: 14-1/2", 15", 16", and 16-1/2"
Axle rating: 5,200 lbs, 6,000 lbs, and 7,000 lbs
You can contact us by filling in the form on the right hand column of the ad listing:
http://www.airstreamclassifieds.com/...es-5-2k-to-7k/
jkinslan is offline   Reply With Quote
mixing self adjusting with manual electric brakes griffithj Brakes & Brake Controllers 11 04-29-2019 05:06 PM
Self adjusting electric brakes. Inland RV Center, In Brakes & Brake Controllers 3 05-20-2009 05:51 PM
Brakes, Left or Right Hand coffeydelsol Brakes & Brake Controllers 9 02-17-2009 07:20 AM
