Old 12-03-2019, 09:50 AM   #1
VDR928's Avatar
2012 23' FB International
Charlotte , NC
EEZTire-TPMS Real Time/24x7 Tire Pressure Monitoring System (TPMS4) - 4 Anti-Theft Sensors
Title: Add New - Airstream Trailer Classifieds - Airstream Trailers For Sale
I just posted a new ad on Airstream Classifieds.
We used this for 3 months and when we bought a new TV it had a tire monitoring system built in. Works great and is like new. From Amazon: (Where we purchased)
â–* REAL TIME/24x7 SAFETY & HIGH FUEL ECONOMY - EezTire TPMS system by EEZ RV Products is the industry leader in the RV TPMS market since 2005. It accurately monitors tire pressure and temperature for up to 26 tires and handle tire pressure up to 210 psi. EezTire TPMS system gives you PEACE OF MIND 24 x 7 when you are on the road or off the road. Maintaining proper tire pressure at all times ensures vehicle safety and helps achieve desired fuel economy
â–* ADVANCED TECHNOLOGY ALERT SYSTEM - the monitor is motion sensitive and monitors tire pressure and temperature on 6-second intervals continuously. It sends visual and audio warning alarms immediately when tire pressure or temperature falls outside the preset safety parameters. The monitor goes into power saving mode if no motion is detected in 15 minutes to save battery. The sensors send status signals to the monitor on 6-second intervals continuously as long as the sensors are under pressure, so your tires are monitored 24 x 7.
EASY OPERATION & MAINTENANCE - EezTire TPMS monitor has one of the largest display screen on the market 4 ½” x 3”. It takes minutes to setup and program. The monitor has a built-in rechargeable internal lithium battery that lasts up to 60 hours on a charge. Sensors have replaceable batteries. It comes with a common USB charging cord that can be connected to vehicle’s cigarette lighter or USB port.
MULTIPURPOSE - TPMS monitor has separate controls for RV and trailer sensors which allows owner to turn off trailer control when driving RV only. The monitor can be programmed with anti-theft sensors or flow-through sensors or different combinations of both sensors to meet the needs of different tires. A booster can be added to boost signal and overcome distance and electromagnetic interference challenges. A basic TPMS system starts with 4 sensors (TPMS4) and could go up to 26 sensors (TPMS26).
You can contact us by filling in the form on the right hand column of the ad listing:
http://www.airstreamclassifieds.com/...theft-sensors/
VDR928 is offline   Reply With Quote
Tire Pressure Monitoring Systems (TPMS) Drathaar Tires 40 02-06-2016 06:09 AM
Tire Pressure Monitoring system chirocruzr General Motorhome Topics 10 04-17-2009 10:08 AM
Canadian Tire's $129 Tire Pressure Monitoring System SilverCottage Tires 9 10-30-2007 08:55 PM
PressurePro Tire Pressure Monitoring System 68 Overlander Commercial Listings 21 09-21-2007 04:49 PM
