Old 02-13-2016, 09:51 PM   #1
1976 23' Safari
east providence , Rhode Island
76 airstream safari Door lock and exterior light
Title:
I just posted a new ad on Airstream Classifieds.
looking for the circlular light that goes to the right of the door(exterior) and a door lock /handle
thank you,i am brand new to forumns.Hope I am doing this the right way
You can contact us by filling in the form on the right hand column of the ad listing:
http://www.airstreamclassifieds.com/...xterior-light/
rosamax is offline   Reply With Quote
Old 02-14-2016, 06:33 AM   #2
Mixter's Avatar
1976 27' Overlander
The lock for your year is a KT lock. You can still get them, but ve prepared for sticker shock. They are $500--$600.
There is a replacement "kit" that is intended to delete the KT lock and install a more generic and readily available Fastec lock, but if your door, latch and catch areas are in good shape, I would go with the quickest solution and just put it bajck the way it was with a new KT lock. You "may" be able to get parts if yours just had a broken pin. But changing the lock is riddled with ramifications and probably shouldn't be done unless you have to.
The round light is known as the "scare" light. Also still available, but you can upgrade to LED version. I think i paid $30-$50??
Out of Doors Mart is a good source in NC. Inland RV is in CA. Vintage Trailer Supply is great. And Airstream Supply.
Sounds like you'll be getting to know these suppliers.
Good luck.
Mixter is offline   Reply With Quote
Old 02-14-2016, 06:47 PM   #3
1976 23' Safari
thank you
thank you so much for your help
Old 02-14-2016, 06:49 PM   #4
1976 23' Safari
thanks
and the enterance whole lock is not even there/totally missing just the rectanglar hole- and same with the light
Old 05-04-2016, 12:59 PM   #5
1969 31' Sovereign
Gig harbor , Washington
Got em let's bargain mines 1969
Poorbaby is offline   Reply With Quote
exterior door latch/lock/keys from 1992 Airstream Skatiero Airstream Classifieds 0 12-26-2013 07:26 PM
Door Lock Loose interior Lock Pin.. Bootsinister Doors & Locks 12 10-08-2012 10:19 AM
Exterior door lock replacement 1986 Excella kellywood Doors & Locks 3 07-25-2011 06:34 AM
Help! Exterior door lock removal 1970 Safari Arizonachip Doors & Locks 3 08-25-2009 06:10 AM
Broken Exterior Door Lock fmzjwill Doors & Locks 37 03-28-2004 03:21 PM
