Title: 2014 Airstream International 23 - Florida
I just posted a new ad on Airstream Classifieds.
A rare pre-owned 2014 Airstream Signature 23D! In phenomenal shape, everything is original and customized. The unit will be professionally cleaned and detailed along with a free prep of propane and battery. We finance everyone!!!
This Airstream International with an interior from award-winning architect and designer Christopher C. Deam that allows light to pour in the panoramic windows and reflect off sleek polished surfaces to create an environment that simply takes your breath away.
Every color, shape, surface and texture contributes to an atmosphere of relaxed modernism. Luxurious fabrics and thoughtfully concealed storage, coupled with rich modern colors, make this a truly Signature experience. The International Signature – it’s highway couture.
Exterior Length 23' 9"
Exterior Width 8'
Interior Width 7' 7"
Exterior Height with A/C 9' 5"
Interior Height with A/C 6' 4.5"
Hitch Weight (w/LP & w/o options, water & cargo) (lbs.) 467
Unit Base Weight (lbs.) 4,806
Gross Vehicle Weight Rating (lbs.) 6,000
Net Carrying Capacity (NCC=GVWR-UBW) (lbs.) 1,194
Fresh Water Tank (gal.) 39
Black Water Tank (gal.) 18
Gray Water Tank (gal.) 30
Water Heater w/electronic ignition (gal.) (XT) 6
A/C w/heat pump (BTU) 13,500
Furnace (BTU) 18,000
LPG (2 - 30 lb. steel tanks) 60
Deep Cycle Battery (lead acid) Group 24 2
Sleeping Capacity 2-4
You can contact us by filling in the form on the right hand column of the ad listing:
http://www.airstreamclassifieds.com/...al-23-florida/
