Title: 1975 Airstream Tradewind 25 - Florida
I just posted a new ad on Airstream Classifieds.
For Sale is a renovated 25′ 1975 Tradewind. It is the pull out double floor plan. The Airstream currently sleeps 3 but the rear gaucho (currently a twin bed) can be easily reconfigured to sleep 4. A lot of hard work has been put into this airstream, so it is ready to hook up and hit the road. Reason for selling is I just relocated for a new job and dont have the space to store it or extra time to travel anymore.
All New floors, New Kitchen, NEW AXLES, New tires. Call or email for more info. See below for the rest of the work recently done.
Below is a list of updates completed over the past 4 years. It is extensive and this Airstream is 100% ready to go.
Exterior:
-2 NEW complete axle set ups w/10″ brakes from Colin Hyde Restoration installed April 2015!
-4 NEW Tires in April 2015
-NEW Zipp Dee awning
-Old belly pan removed, old batt fiberglass insulation removed from belly pan
-frame corrosion repaired
-new outriggers installed
-frame sandblasted and treated with POR15 rust converting/preventative paint
-front toungue sandblasted, primered and painted
-closed cell insulating spray foam sprayed on floor
-grey water tank holding box properly insulated
-belly pan replaced with new aluminum sheet metal and proper ventilation installed
-new 3/4″ marine plywood fresh water tank support installed w/double foil bubble insulation
-installed receiver hitch in rear bumper for bike rack
-front fold out steps rebuilt with new slide outriggers installed
-floor and side joints sealed properly
-new beltline molding installed and properly sealed
-all exterior seams caulked
-propane tanks painted and re-certified with OPD valves,
-new electric front tongue jack with LED light installed
-new break-away brake safety switch instaled,
-new exterior running lights front and rear,
-new taillight lenses and new porch light lens
-new tag light and bracket,
-optional factory slotted mag wheels,
-optional factory tinted front window stone guard
-2 Segment Rock Protectors installed on front corners
Interior:
-NEW Kitchen and Pantry
-New Countertops
-New Custom Kitchen Cabinets
-New Atwood 3 Burner Stovetop
-bathroom removed to access bad flooring at rear wall-repair made with marine plywood
-bathroom plastic primered and painted celery in color with royal blue for tub
-bathroom ceiling painted
-new bathroom light fixture installed
-new linoleum flooring in bathroom
-new stainless steel hand rails installed in bathroom, shower and doorway
-floor repaired at front door with marine plywood
-new wood/laminate birch flooring installed
-all windows rebuilt with new weatherstrip, screens, frames painted, hardware cleaned and painted
-new interior light fixtures w/LED’s
-roof vents (3) rebuilt with new gaskets, insulation, hardware cleaned and lubricated
-new front fold out couch with under seat storage
-electric/gas refrigerator works perfectly with new freezer gasket and new hinge kit installed
-new Wineguard HD amplified TV antenna installed
-TV cable connection installed
-A/C coils cleaned, new air filter installed
-A/C works great and also has heat function
-new breakers installed in breaker box
-custom fitted Levelor SS blinds installed
-New Roller Shades Installed
-sky view windows repaired, cleaned and resealed
Plumbing Work:
-NEW hot water heater
-all new hot and cold Pex water lines
-new bathroom faucet fixture
-new kitchen faucet fixture
-shower faucet rebuilt with new shower head
-new Thetford toilet water control valve W/seal kit installed
-new Thetford black and grey water dump valves
-new roof top plumbing vent seal kits (3) installed
Accessories Included:
4 Leveling Pads
4 Wheel Chocks
4 Wheel Covers
100W Solar Panel
You can contact us by filling in the form on the right hand column of the ad listing:
http://www.airstreamclassifieds.com/...-25-florida-2/
