Old 09-22-2013, 05:32 PM   #1
Full Time Alumaloafer
louaxtjr's Avatar
1966 24' Tradewind
Livingston , Texas
Images: 12
130-watt Portable Solar
Title:
I just posted a new ad on Airstream Classifieds.
Solarland 130-watt portable solar charging system
• Built in 3 stage PWM charge controller with bulk, absorption, and float modes.
• Produces 50-60 amp/hours per day in full sun
• 7.5 amp operating current* (approx)
• 17.2V max operating voltage
• 14.4V peak charge voltage (temp compensated)
• 13.8V float mode
• Compatible with Lead-acid, Gel, or AGM type batteries
• Indicator lights confirm proper operation
• 16′ connection cord standard, 25′ extensions available
• Padded aluminum storage case
• Dimensions panels folded: 40″x21″x3.5″, 39 lbs.
• Dimensions panels open: *41″x40″x1.5″
• Dimensions of metal case: *41″x22″x5″ 17lbs.
• Selling due to switching to a roof-mounted system for use in Arizona
• Purchased in April of 2013 for $645, used weekends for about 3 months
Lou Axt
413-672-1438 voice or contact via airforums
You can contact us by filling in the form on the right hand column of the ad listing:
http://www.airstreamclassifieds.com/...ortable-solar/
louaxtjr is offline   Reply With Quote
