Old 11-30-2014, 10:47 AM   #1
Water leak above dump handle?
Hello guys,
My 2015 27 fb eddie bauer seems to have a slow drip coming from above the gray water dump handle. It is also starting to drip from the led light gasket between the dump handles.
There is copper plumbing that extends up and into the body just above the gray water dump valve and it's coming from there. I looked under the closet to see the upper portion of the pipe and it's dry.
I'm located outside of vegas and I'm fulltiming. It has dropped below freezing a few times. I use the furnace on cold nights to keep the pipes warm. I'm plugged into city water all the time and use a heated water hose.
Any ideas?
Thanks!
jamesk is offline   Reply With Quote
Old 11-30-2014, 10:53 AM   #2
TinTin's Avatar
2009 23' FB Flying Cloud
Canmore , Alberta
Black tank flush line leaking? Does the leak appear to be coming through a seam in the belly pan?
Bob and Nancy
http://www.rwcphoto.smugmug.com
Cheer Up, Slow Down, Chill Out!
TinTin is offline   Reply With Quote
Old 11-30-2014, 11:06 AM   #3
Coming from the seam where the pipe meets the belly. I did flush the black tank a couple weeks ago...
Old 11-30-2014, 11:06 AM   #4
My black tank was reading at 10 percent when it was dumped as well
Old 11-30-2014, 11:13 AM   #5
TinTin's Avatar
Canmore , Alberta
I have read of black tank flush lines leaking onto the belly pan, could be caused by freezing but more likely came with a bad connection from the factory. Regardless of the cause of your leak, I would call for a warranty repair.
Bob and Nancy
Old 11-30-2014, 12:01 PM   #6
airdreamers's Avatar
2008 28' International
Venice , Florida
Images: 14
Originally Posted by jamesk View Post
Hello guys,
Any ideas?
Thanks!
2015: Find the nearest dealer, they fix it, your happy and go on your way!
What is better then a FREE FIX!
Bill and Janice, We're lovin' it! (Airstreaming)
Airdreamers
WBCCI #8880
AIR #41310
airdreamers is offline   Reply With Quote
Old 11-30-2014, 01:28 PM   #7
The nearest dealer is four hours away and this is my fulltime residence. It will be annoying, but you're right. If it's a quick fix I can do myself, it'd be better for me is all.
Old 11-30-2014, 05:52 PM   #8
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
The anti-siphon valve seems to be a weak point in this part of the Airstream. Check out this thread and see if it pertains to you. If it is the anti-siphon valve, the repair is easily accomplished provided you are moderately handy. All you need to know is in this thread:
http://www.airforums.com/forums/f444...ak-124696.html
Good luck!
Bob Martel
WBCCI# 5766
Old 12-01-2014, 12:17 AM   #9
Thanks for your help annarborbob, I took the closet panel out and looked at the valve.. it seems dry. It's been weeks a week or two since I've used it anyway. Everything seems dry down below.
I think there is a leak in between the panels somewhere or under the actual floor.
Old 12-01-2014, 07:57 AM   #10
Chelsea , Michigan
Images: 12
That was the easy fix, I'm afraid it's time for the dealer visit. Please report back when you've got the solution so we can all learn. Thanks, Bob
Bob Martel
WBCCI# 5766
Old 12-10-2014, 12:19 PM   #11
mefly2's Avatar
2015 25' FB Eddie Bauer
Yes, waiting to hear the outcome ...
Dump Valve Handle - broke... Craig Waste Systems, Tanks & Totes 11 01-22-2011 07:46 AM
Water leak just above battery boxes, 1979 blickcd Leaks - Weatherstrips, Gaskets, Caulks & Sealants 6 02-19-2009 10:28 AM
Leak above front window Greg26 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 8 09-07-2008 09:14 AM
Water Leak above Black water tank temcotom Waste Systems, Tanks & Totes 1 06-29-2005 11:03 PM
black tank leak above valve gary Waste Systems, Tanks & Totes 2 06-03-2004 08:42 AM
