Old 10-21-2014, 07:56 PM   #1
peetoe's Avatar
2012 25' FB Eddie Bauer
SLC , Utah
Rub Rail ?
This is my first post. I have a 2012 Eddie Bauer. I bought used about 3 months ago. The Right fender came off with the original owner. The left side isn't far behind. the double sided tape is failing. I feel it looks better of but I have about a 6 inch section that now needs Rub- rail to clean up the look. I can find the exterior rubrail on out of doors mart with the double sided tape. I cannot find the part that attaches to the camper and then what the Rub rail is taped to. Thanks for your time
peetoe is offline   Reply With Quote
Old 10-21-2014, 09:27 PM   #2
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
rub rail? do you mean the little insert inside of the beltline aluminum trim?
Peace and Blessings..
Channing
WBCCI# 30676
Old 10-22-2014, 08:16 AM   #3
peetoe's Avatar
SLC , Utah
Originally Posted by peetoe View Post
this is my first post. I have a 2012 eddie bauer. I bought used about 3 months ago. The right fender came off with the original owner. The left side isn't far behind. The double sided tape is failing. I feel it looks better of but i have about a 6 inch section that now needs rub- rail to clean up the look. I can find the exterior rubrail on out of doors mart with the double sided tape. I cannot find the part that attaches to the camper and then what the rub rail is taped to. Thanks for your time
Old 10-22-2014, 07:53 PM   #4
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Ok.. you are missing the 'beltline' trim.. looks like previous owner had a tire let go or other damage in the area. Rather than remove the whole length of the beltline and replace, they cut it off shorter... a hack of a fix..
So you will have to get the replacement beltline, pull off the 'insert', drill out all the rivets from the remaining length to the next section where it started. I looked on outofdorrsmart.com they did not have the metal 'beltline' rail that I could see.. they have the 'insert' which is the chrome thing in the center.. chances are, the 'insert' is barely stuck to the beltline rail...
You may have to find them from Airstream directly.
Channing
WBCCI# 30676
Old 10-22-2014, 07:56 PM   #5
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
BTW.. here is a shot of my 'beltline' I am currently working on..
Channing
WBCCI# 30676
Old 10-22-2014, 08:28 PM   #6
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Lookieeeee what I found...
EXTRUSION BELTLINE MOLDING (SOLD IN 16' PC)
Channing
WBCCI# 30676
Old 10-22-2014, 09:41 PM   #7
peetoe's Avatar
SLC , Utah
Awesome. Thanks for finding that I really appreciate it.
Old 11-24-2014, 07:14 AM   #8
2015 27' FB Eddie Bauer
Aston , Pennsylvania
Did you replace the exterior green rubrail? How bad is it to replace?
BASE729 is offline   Reply With Quote
Old 11-24-2014, 10:08 PM   #9
peetoe's Avatar
SLC , Utah
No I pulled off both fenders on the left and right side. Winter came to fast this year. I put it off till the spring.
Old 11-24-2014, 11:16 PM   #10
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
"replace" of the rail is not difficult.. drill out the old rivets, pull off the old rail, drill the NEW holes in the NEW rail is the 'hard part'... getting them to line up... but it is worth it.. and can be done.
Rivet in the new rail, replace the center trim... go camping.
Channing
WBCCI# 30676
Old 11-25-2014, 06:31 AM   #11
Actually I was referring to the plastic/rubber insert in the rubrail. Not sure if its adhesive, taped, or other. Just me being vain... I have a blacked out truck and was looking to replace the (in my opinion) god awful green band that runs around the EB model with black. That and a quick paint job on the emblem and the trailer matches the truck.
Old 11-25-2014, 08:33 AM   #12
1976 31' Sovereign
Oswego , Illinois
Out of doors mart & inland trailer both carry vinyl insert.
Old 12-03-2014, 11:14 AM   #13
StagrLee's Avatar
Didn't know they offered two AC units with the 25' EB's. Nice!
"Stagr" Lee
2012-1/2 25' Eddie Bauer
StagrLee is offline   Reply With Quote
Old 12-03-2014, 12:38 PM   #14
I don't know if they do... but the photo is a 27' EB with (2) AC units.
Rub Rail, Rub Rail 'where art thou?' Radman Clearcoat, Exterior Paint & Trim 18 08-09-2017 08:27 PM
Rub Rail Replacement Question ViewRVs Clearcoat, Exterior Paint & Trim 6 07-06-2003 01:35 PM
blue rub rail paul k Clearcoat, Exterior Paint & Trim 0 04-27-2003 12:52 PM
black rub rail and trim insert wb13798 Airstream Motorhome Forums 2 01-30-2003 12:10 PM
