Old 07-19-2019, 01:38 PM   #1
Senior Member
sheriff1's Avatar
2012 27' FB Eddie Bauer
Sparks , Nevada
Replacing running lights
Bought new running lights with the correct curved bases and gaskets. Wondering if anyone has had success in getting the main wire out through the hole to attach the new wires to or are we just cutting the wires off at the light and splicing onto the old pigtail.
Thanks!
sheriff1 is offline   Reply With Quote
Old 07-19-2019, 02:04 PM   #2
Overkill Specialist
GMFL's Avatar
2014 23' International
Dadeville , Alabama
Here you go...
http://www.airforums.com/forums/blog...lacement-3015/
Dept of “OverKill”
@Airstream_Nuts_And_Bolts
Old 07-19-2019, 02:29 PM   #3
Senior Member
sheriff1's Avatar
Sparks , Nevada
Found that, just verifying if anyone was able to expose the original splices to splice in at that point rather than use the exposed pigtail.
Thanks!
No running lights, brake lights or trailer lights work from tow vehicle RichHog 1969 - 1973 Safari 42 05-02-2019 07:42 PM
Running Lights don't work, Other exterior lights work jrvly1976 Lights - Interior & Exterior 15 01-27-2015 09:27 PM
No running lights or tail lights... goswick Lights - Interior & Exterior 24 02-27-2010 09:31 AM
Replacing the running lights Devoman Lights - Interior & Exterior 7 03-13-2006 08:28 PM
Running Lights/Backup Lights 85 Sovereign GRAYMAN Lights - Interior & Exterior 7 08-10-2004 08:54 AM
