Old 10-25-2015, 07:53 PM   #1
Some Guy
djarrett's Avatar
2018 28' Tommy Bahama
Nashville , Tennessee
LED Puck Lights
We have a 25' foot EB and while some like the 27' for the bed arrangement, we like the length for our purposes.
However, on the 25' they have LED Reading lights mounted under the sliding storage unit as well as mounted to the wall above the head of the bed. I keep knocking my head on these two reading lights that hang down from the sliding storage area. I'd like to replace them with two of the LED Puck lights like those over the kitchen counter.
Anyone know what brand they are?
D
The Jarretts
Nashville, Tennessee
2018 27' Tommy Bahama
2015 F250 TV-Petrol
WBCCI # 22342
djarrett is offline   Reply With Quote
Old 10-29-2015, 11:56 PM   #2
dmcgaugh's Avatar
Seattle , Washington
Yes, these are the ones:
http://www.itc-rv.com/product/decor-...verhead-light/
I actually went through the the (expensive) ordeal of replacing every light in our EB to switch to soft white because the bright white was giving us headaches. With the exception of the light in the shower, closet, and storage compartment, ITC makes every light in the trailer.
dmcgaugh is offline   Reply With Quote
Old 10-30-2015, 04:55 AM   #3
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
I get all our AS LED's from Dan @ LED for RV
but Im the Husband, so we went to Cleveland. 😘
RLC
Its a crooked piece of time that we live in.
John Prine
Old 10-31-2015, 09:05 PM   #4
Some Guy
djarrett's Avatar
Thank you folks ... ordered.
The Jarretts
2015 F250 TV-Petrol
WBCCI # 22342
Old 10-31-2015, 09:31 PM   #5
amaier7771's Avatar
2013 25' FB Flying Cloud
Colorado Springs , Colorado
What was involved to remove the existing bright-white's from the AS? DO they just pop out if you pull on them, or do you need a tool?
amaier7771 is offline   Reply With Quote
Old 10-31-2015, 10:10 PM   #6
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
Just an FYI, if you're paying over $1 per LED puck you are being ripped off.
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
BoldAdventure is offline   Reply With Quote
Old 10-31-2015, 10:26 PM   #7
dmcgaugh's Avatar
Yes, the ones in the ceiling, you can just get your finger underneath the edge and pull straight down. There are two spring clips that hold them in place when they are in the ceiling. The surface mount puck lights are much more difficult to remove. I was not able to remove them without destroying the the metal finish -- which was fine since I had new ones to replace them with.
Old 10-31-2015, 10:33 PM   #8
A buck a puck.....sounds like a quality fitting for your AS.
RLC
John Prine
Old 01-27-2017, 01:17 PM   #9
2004 22' International CCD
2015 30' International
Box Elder , South Dakota
Several of my Airstream-original surface-mount LED puck lights (like over the kitchen sink) on my 2015 are burning out. Airstream sent me replacements. But I cannot get under the metal edge to pry the LED fixture open in order to unscrew it from the cabinet surface. Can anyone advise me on what tools or techniques to use to pry this thing apart? I don't care if I destroy it, but I don't want to damage the cabinet! Screwdrivers, nail files, etc have not worked for me. Fingernails are not nearly strong enough.
The industrial design is not great -- I can barely open up the new ones by pressing firmly on the reverse, inner area that's inaccessible when they are mounted.
Thank you!
lbdesign is offline   Reply With Quote
Old 01-27-2017, 02:36 PM   #10
The Myth
Killeen , Texas
I used a plastic putty knife to take mine out. you could possibly use a metal putty knife if you tape it up with masking tape.
JPAS is offline   Reply With Quote
Old 01-29-2017, 02:25 PM   #11
Some Guy
djarrett's Avatar
To be clear, I removed the two drop down swivel post reading lamps that I was continually clocking my head on with the true hanging hockey puck LED lights (OEM - as they match others in the unit). I did not replace any of the recessed lighting pucks. The hanging puck had a turn off surround, and then some screws holding the base plate. It was a 10 minute replacement for both lights.
D
The Jarretts
2015 F250 TV-Petrol
WBCCI # 22342
Old 01-29-2017, 02:39 PM   #12
StagrLee's Avatar
2012 25' FB Eddie Bauer
Sometimes a picture helps... I had lots of wiring issues with my puck lights in my EB. Took me a while to figure it out
http://www.airforums.com/forums/f447...ss-151546.html
"Stagr" Lee
2012-1/2 25' Eddie Bauer
StagrLee is offline   Reply With Quote
Old 01-30-2017, 02:05 PM   #13
I bought a new paint scraper per JPAS' advice to try a putty knife. It was very sharp and it worked! Thank you!
(this is on getting a tool under the outer lip of the puck light collars)
And amusingly, the moment I replaced the one, its neighbor started to flicker...
Old 01-30-2017, 02:21 PM   #14
runnersg's Avatar
2016 27' Eddie Bauer
TX , Texas
I replaced nearly all of mine in a 2016 Eddie Bauer. Your fingers can get underneath them... and I've not blemished the airstream in any way and I haven't been easy on them while removing. Replacement is a snap. I suspect they have a bad supplier or a bad run of LEDs. Honestly, I've replaced at least 10 and just requested 4 more replacements under warranty.
2016 Eddie Bauer 27'
runnersg is offline   Reply With Quote
Interior Flouresent lights to LED PUCK J&G22argosy Lights - Interior & Exterior 5 10-05-2013 08:35 PM
LED puck lighting suggestions Tedboxer Lights - Interior & Exterior 13 06-14-2013 05:45 AM
Moving from center lights to multiple puck lights mikeandnora Lights - Interior & Exterior 10 02-11-2011 09:47 AM
Hampton Bay LED puck lights Chuck Lights - Interior & Exterior 2 06-17-2008 08:13 PM
Puck Lights on closeout at Walmart swebster Electrical - Systems, Generators, Batteries & Solar 4 05-15-2005 10:05 AM
