Old 08-09-2015, 07:35 AM   #1
2013 27' FB Eddie Bauer
Salado , Texas
Electronic boxes and switch in fwd external compartment
(Also posted under Electric- but no replies so far) We just purchased a very slightly used 2013 27' FB-EB w/factory installed Solar. In the front, exterior storage compartment, on the left as seen looking in are a couple of electronic/electrical boxes, one of which has an obvious toggle switch sticking up. What are these boxes and what does the switch do?
Thanks in advance.
Jeff McClure
Loden is offline   Reply With Quote
Old 08-09-2015, 11:14 AM   #2
jayseejay's Avatar
2015 27' FB Eddie Bauer
2011 25' FB Flying Cloud
Fernandina Beach , Florida
Hi Jeff. One of those boxes should be your inverter, if your layout is at all like mine. I believe the toggle switch is a means to turn it on/off manually, as opposed to using the remote switch on the galley wall. Joe
jayseejay is offline   Reply With Quote
Old 08-09-2015, 11:17 AM   #3
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
It looks like there is writing on the box. Can you read it?
MICHAEL
Old 08-11-2015, 05:08 PM   #4
Salado , Texas
I would have to do some serious crawling and twisting to get where I could read it, but will try to get a camera in place. It does look like an inverter based on the size and shape, but I will try to get an image.
Old 08-11-2015, 07:28 PM   #5
1979 23' Safari
Wayland , New York
Nice of them to make things accessible.
Old 08-11-2015, 08:03 PM   #6
2016 30' Classic
Erie , Colorado
Unless it is elsewhere in addition to the inverter (if you have an inverter) might also include the DC plus and minus bars and the transfer relay.
Gary
2015 Classic
2015 GMC Sierra 2500HD Duramax
ProPride
NVPN
ghaynes755 is offline   Reply With Quote
Old 08-11-2015, 09:13 PM   #7
Ohiobrits's Avatar
2015 27' FB International
Howard , Ohio
The first black box is the junction box for the 7 pin connector. Behind will be the inverter which has a large fuse on the red positive line with a black cover. The inverter also has a regular 110v plug which is coiled up and not used. Looks like you can just see the light grey phone line that connects the inverter to the remote switch in your galley area. The 12V disconnect switch/relay is here (the one you can hear click when you put your battery in store mode). The are positive and negative bus bars that collect various 12V wires. There are various lengths of spare cable bundled up also . It's a rats nest in there!
Picture from my 27FB International below.
Name:	ImageUploadedByAirstream Forums1439349122.627395.jpg
2015 27FB International Signature "Danielle"
ProPride / 16" wheels / 600W solar / 864 AHr Lithium
Victron MultiPlus Inverter / BlueSolar / ColorControlGX / BMV 702
Porsche Cayenne Diesel
Ohiobrits is offline   Reply With Quote
Suburbans, Escalades going to FWD! Road Ruler Tow Vehicles 21 11-09-2008 01:54 PM
Looking at Chevy 3/4 ton van with Quigley fwd & 5.7 Litre..thoughts? johnboy Tow Vehicles 8 06-05-2006 09:31 AM
