Old 08-05-2014, 10:35 PM   #29
BassCan's Avatar
2014 27' FB Eddie Bauer
Mobile , Alabama
Our back hatch can be difficult to open at times, after reading Foiled Again and MeFly's post went out to evaluate our hatch.
Won't you know it, I had no problem opening it today. On some days I would have to struggle with the handle. My observations of the locking pins:
When in the closed and locked position the locking pins in our EB are approximately 1 1/2 inches extended beyond the hatch
when turning the handle to open position, the locking pins are about 1/2 inch out but no longer engaging the holes on the sides of the trailer, thus facilitating the hatch opening.
i imagine that the lease bit of miss alignment would cause the hatch to either jam or not be secured at all.
BassCan is offline   Reply With Quote
Old 09-08-2014, 09:24 PM   #30
jasperkins's Avatar
2012 27' FB Eddie Bauer
colorado springs , Colorado
I had the factory replace the lock, roller shade, and recalibrate the whole back door locking ping mechanism right before the warranty ran out :-)
jasperkins is offline   Reply With Quote
Old 09-09-2014, 02:15 PM   #31
BassCan's Avatar
Mobile , Alabama
That was a good ideal Jasperkins. We have the same model.
Did you do a leak check?
Old 09-11-2014, 11:02 AM   #32
jasperkins's Avatar
No leaks. At least not by door yet :-)
Old 09-16-2014, 05:57 PM   #33
jwp
seattle , Washington
any of you know off hand the clear pass through width of the hatch? I know it's right around the 40" +/- range but an inch or two +/- could make a big difference
researching, learning, looking for the right Airstream
jwp is offline   Reply With Quote
Old 09-16-2014, 06:15 PM   #34
crisen's Avatar
2012 25' FB Eddie Bauer
Fairbanks , Alaska
Mine is here at work so went out and measured it. Inside dimension on the door opening width is 46 1/2" However the gas struts are what would be limiting factor. With the door fully open they are 44 3/4" at the bottom of the strut tube and 44" at the top of the tube. They slant inward due to the mounting position on the door. Hope this is clear.
Rick
"When you find yourself in a hole - quit digging!"
2012 1/2 Eddie Bauer, 2016 Ram Laramie 3500 SWB 4x4 6.7L Cummins 68RFE
crisen is offline   Reply With Quote
Old 09-17-2014, 05:21 PM   #35
jwp
ok, thank you very much for the measurements !
Old 09-05-2017, 11:55 AM   #36
Chicago , Illinois
Originally Posted by BassCan View Post
Forgot to mention that two things were broken in the 16 days of camping. The kitchen counter extension pop off when our 19 y/o son was trying to get out the door while it was extended. Looks like small wood screws were holding it in place and The bedroom towel rack broke off while stuffing a beach towel on it.
I had one of the towel racks in the bedroom break as well and I'm having trouble finding the right replacement SKU. Do you have it by chance? Thanks.
joleary60 is offline   Reply With Quote
25 FB Eddie Bauer :: 2012 Airstream Eddie Bauer Jennybeth Airstream Registry Discussions 0 09-26-2013 06:28 PM
Eddie Bauer :: 2012 Airstream Eddie Bauer 25' FB screamstream Airstream Registry Discussions 3 12-12-2011 03:00 PM
