Old 12-22-2014, 06:34 AM   #1
2015 27' FB Eddie Bauer
Aston , Pennsylvania
EB Sunbrella color spec
Does anyone know the actual color name of the tan sunbrella in the EB's? I found a few different custom seat cushion websites that use sunbrella and allow for custom cushions.
I had wanted to make a custom cushion and backrest for the dinette that doesn't steal all the other cushions in the rear of the EB. The fabric being an exact match would be perfect.
Here is one of the sites, there are many:
Custom Cushions & Pillows for Outdoor Furniture | Cushion Source
BASE729 is offline   Reply With Quote
Old 12-22-2014, 06:40 AM   #2
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
Here is the Sunbrella web site. You might be able to figure it out from this. Also, you might call Airstream Customer Service (Dan Snyder, Customer Service Manager 877-596-6111 X7408) to see if they can help identify the actual color for you. When you figure this out, kindly post here so we can all save the information for future reference.
Fabric Showroom: Sunbrella fabrics
Bob Martel
WBCCI# 5766
Old 12-22-2014, 08:34 AM   #3
Home of Vortex tuning
CDONA's Avatar
2013 27' FB Eddie Bauer
Spearfish , South Dakota
I'm in the process of replacing the big wedge of the the starboard side dinette with what is used on the port side, (smaller wedge)
The upholstery shop here in Havasu had fabric swatches of sunbrella and matched mine perfectly. I didn't get a name or number of the swatch, I didn't need to know.
The info is out there, , ,
"Chip Tank" is in Westwood Ca.
CDONA is offline   Reply With Quote
Old 12-22-2014, 08:50 AM   #4
Keen amature
martin300662's Avatar
1975 20' Argosy 20
Chestfield , Kent
Crate and Barrel stock Sunbrella by the yard in their fabric department, and carry the swatches in most stores that have a fabric department.
martin300662 is online now   Reply With Quote
Old 12-22-2014, 09:19 AM   #5
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
If you don't want an almost perfect match, to get an exact match take a sample with you when you buy, even store light will change color appearance. Nothing matches Sunbrella for durability and color retention.
Old 12-23-2014, 10:13 AM   #6
CDONA's Avatar
I remembered she put a part number on my work sheet for the needed sunbrella material
5476-0000
I can't say if this is a factory part or a supplier/vendor part number
Old 12-23-2014, 10:34 AM   #7
Keen amature
1975 20' Argosy 20
Chestfield , Kent
That is the code for Sunbrella Canvas Heather Beige
Not sure if that is what you are looking for, but that's what it is.
Old 12-23-2014, 11:13 AM   #8
That's exactly what I was looking for. I have them sending a swatch of that material out to verify. I'll update when I receive it. Thanks!
Old 12-24-2014, 09:59 AM   #9
CDONA's Avatar
She put their swatch up against my seat cushion for the match.
All my stuff goes in 1/7/15 for the work
Old 01-12-2015, 05:52 AM   #10
I got the color swatch. I laid it on the existing fabric for comparison. While the lighting shouldn't make a difference since its fabric on fabric, I will say that in person, the material looks to be a better match than the photo.
I'm laying out the U-Lounge now. The plan is to make a bench seat that spans between the two existing benches. When I use the tabletop, its more of a bed and not anywhere that's convenient to sit. By making a smaller insert, it should be a true three sided lounge.
Once that's done, I plan on having a smaller table top made that only utilizes one of the table legs. Just have to see how wobbly that would be. It would be a very small table top surface. We'll see.
Old 11-18-2017, 08:54 AM   #11
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Slight hijack. My cushions will need new foam before too long and I have considered going to ultraleather... BUT I love the look of the quilted back pieces. I've seen newer EBs with ultraleather but only in black and deep brown, and a quick search for quilted ultraleather doesn't bring up anything in a beige/camel hue.
I want to match the current color as close as possible, but not if I'd have to quilt it myself, (really need a special long arm multi head commercial machine to quilt 3 layers together without slippage that will look like sh**). Anyone seen any quilted synthetic leather in the right tone?
Thanx
Old 11-18-2017, 11:01 AM   #12
CDONA's Avatar
I would look to a custom setup rather than what is available from the factory.
I'm not a fan of ultra leather, those bottom panels of the seating cushion is tearing around the velcro. I always try to gently pry off, working my fingers into the velcro to do so.
Boat foam over upholstery foam for more support without sitting through the cushion.
A&E Restoration Using Sunbrella Fabric Datta Awnings 5 10-10-2013 05:14 PM
Color temperature and color rendition index of fluorescent tubes Jammer Lights - Interior & Exterior 3 08-16-2010 08:29 PM
Sunbrella Fabric for curtains nd48463 Upholstery, Blinds, Walls & Interior Finishes 8 11-04-2008 12:47 AM
airstream spec range list? the welshman Airstream Trailer Forums 10 01-11-2005 10:47 AM
1982 excella diesel airstream motorhome engine spec's jeniamundo Mechanics Corner - Engines, Transmission & More... 9 11-02-2004 08:24 AM
